Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 09-21-2009, 03:07 PM   #1
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
one of these would make you both very happy.
12 Volt Hair Dryer / Defroster Black RV Camper - $17.23
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 09-23-2009, 07:25 PM   #2
2003 26' Land Yacht-"Bud"
magwa's Avatar
Profile:  coarsegold , California
The Next Stage
Originally Posted by magwa View Post
...snip...I DO KNOW that I want to get at least 2000w, continuous of pure sine. I think I want to go with 12v using 4 6v; 2 in parallel and 2 in series. But I'm not sure about any of it (except my use level) until I hear some more of your experiences.
Looks like I made a deal on a pure sine 3600w (9000w surge) inverter. I think I can fit four 6v's in an area that will work. The inverter has no charger or switch, but it's got a lot of juice. Anyway, the inverter is now not in the question stage. I'm looking to hard wire the inverter into a box by the shore power plug and plug it in (using the shore power cord and plug) when necessary. So...no switch necessary...Maybe later. But if I use 4 6's, what charging set and charger(s) up do you all recommend? I'll put a remote on the charger (or is it "chargers) and only turn it on when on shore power. And does it make sense to go 2 parallel and 2 series to get the 12v? And (I almost hate to ask this) but, what batteries do any of you like. I may have to use an enclosed space under the bed, but open to the basement (rear) storage for the batteries...it's not too far from the inverter site.
magwa is offline   Reply With Quote
Old 09-21-2009, 05:35 PM   #3
Profile:  1963 24' Tradewind
N. Little Rock , Arkansas
Originally Posted by memgrove2000 View Post
Google "butane curling iron" just to help on some of the problem. They are cheap and don't care where you use them.
That is pretty cool. I had no idea they made something like that. Now if someone would come up with a butane Chi.
kaferboy1 is offline   Reply With Quote
Old 09-21-2009, 07:01 PM   #4
magwa's Avatar
Like this?
Old 09-23-2009, 08:36 PM   #5
Grumpycamper's Avatar
Profile:  2005 16' International CCD
Wimberley , Texas
Mine is wired inline as Batwing described and catches a couple of plugs in the kitchen area, the front of the coach which supports the TV and electronics and a plug under the dash I use for the computer. It is wired to 4 house batteries and has a solar panel. It will power the MH 3 to 4 days if you manage the power well, you can run the generator an hour or so a day in the mornings when power useage is high useing blow dryers, coffee pots, electric water heaters, microwave and such. I got a coffee pot with an insulated carafe because the warmer would really drain the batteries. Good luck, an inverter is a great option when you don't have to use air conditioning.
Grumpycamper is offline   Reply With Quote
Old 09-23-2009, 08:58 PM   #6
3 Dog Nite's Avatar
Profile:  1974 25' Tradewind
Cleveland , Tennessee
Food for Thought
Hey magwa, I saw the list of electronics you had listed in post 4. Electronic things like that will use power even when turned off. Be sure to unplug them or have a way to turn off / disconnect the inverter so the electronics don't kill batteries with a ghost draw when not in use.
Ricky
I know the voices in my head aren't real, but some of them have pretty good ideas.
AIR 22749
1974 25' Tradewind - no TV yet
1989 345 LE Classic Motorhome
Courtesy Parking; 20 amp, water, dump, wifi
'tween exits 27 & 33, I-75
3 Dog Nite is offline   Reply With Quote
Old 09-23-2009, 08:57 PM   #7
Wimberley , Texas
It seemed like every time I used my MH one of the house batteries was bad. I don't believe any of them lasted more than a year. After years of problems with high dollar batteries I decided to get a set from Wal Mart for ease of exchanging them. They have been in there over three years without a problem. If you go six volt golf cart batteries Sams has them for a resonable price.
Old 09-24-2009, 01:43 PM   #8
silversuppository
dsrtgrls's Avatar
Profile:  2010 19' Flying Cloud
Clarkdale , Arizona
i stupidly plugged in a small electric heater into the inverter outlet because i am still new to the tech. suffice it to say it tripped it off as i tested the other inverter outlet and it is out as we have a total of 2 inverter outlets. where/how do you reset the inverter. i am in co. camping and would like the outlets to work. thanks if anyone has a rescue.
dsrtgrls is offline   Reply With Quote
Old 09-24-2009, 01:52 PM   #9
magwa's Avatar
I'm no Expert, But I'm Getting Preety Informed
You're camping...At least you have internet.
Which inverter are you running? What MH/TT? If there is no reset on the inverter, you possibly blew a circuit breaker when you overloaded. A simple flip of the circuit breaker switch should do it....without the heater plugged in.
Did you try the socket on the inverter (after a "cooling down" period for you *and* the inverter) with something within the inverter's load range? I'm assuming your batteries are charged adequately.
Again, I'm not the one with good answers...I have mostly questions for the Veteran members here. But I'm on line and would be happy to help if you need me to look up the inverter stats to see if there's a "reset" button or something.
First, I'd start with the above.
Old 09-24-2009, 04:32 PM   #10
silversuppository
dsrtgrls's Avatar
Clarkdale , Arizona
i have to get to the inverter under the dinnette seat and see about that switch you mentioned. i will never do this again so it was a great lesson to a newbie. none of the circut breakers were tripped off that i could see behind the brown door under our closet they were all switched on. the 2 inverter outlets were not listed as being on a breaker like that as far as i could see but this is an adventure and we are hooked to shore power and all the other outlets are working normally.
Old 10-04-2009, 06:29 PM   #11
magwa's Avatar
Finished The Install
Sure enough. I ended up with the Airpax Dimensions 3600N hooked to two 12v Northstar batteries hooked in parallel. These things are 131 lbs each, 170.8Ah deep cycle, and made for the telecom industry. The charger is a Go Power 10 amp, three stage that I have wired in immediately upstream of the shore power plug.
In the bedroom on the wall, I'm using a remote on/off for the inverter, a 110 switch for the charger. I'll turn it "off" when on inverter power. The simple "manual" switch for the inverter/shore power: I get out, open the electrical bay, plug into either shore power or inverter power using the 30amp plug.
I tested the heck out of it and two hours with TV, lights, plugging a mini-die grinder in and turning it on and off, running the air (just for a minute)....all work well and almost no "measured" drop in battery storage. Of course, (also on the bedroom wall) I only have a mickey-mouse volt gage that I'm running remotely. If anyone knows of a good digital gage, that would be a help. All I can find on EBay are garbage Chinese units that are panel mounted.
Anyway, until I report back based upon actual use, "all systems are go". Thanks again to all for the help.
Old 10-04-2009, 09:12 PM   #12
76sovereign's Avatar
Profile:  1976 31' Sovereign
ozark , Missouri
Good to know
http://airstreamremodel.blogspot.com
http://vimeo.com/kani
76' 31' Sovereign
76sovereign is offline   Reply With Quote
Old 10-08-2009, 09:27 AM   #13
silversuppository
dsrtgrls's Avatar
Clarkdale , Arizona
thanks for all who gave help with my blown inverter outlets. it wound up a easy reset. all i had to do was push the inverter button on the wall by the vanity and it all came back. another lesson learned.
Old 10-17-2009, 11:56 AM   #14
Profile:
Smile Inverter System
Go to the Airstream.com site and locate the customer service area which has Motor Home Manuals. Select the 2004 Diesel Motor Coach Manual. This one has the schematics and description of the 12 volt system which incorporates a converter/inverter system that does what you want. This is a relatively complex system that automatically provides computer controlled battery charging and 110 VAC output power on many of the outlet plugs. This is not just a 'buy a few boxes and screw them together' operation. There are many considerations other than just figuring out the loads. As I recall your unit has the batteries in the front compartment, either two or three. Four 6 Volt units would be much better than 4 12 Volt batteries, however, they are much larger and considerably heavier so you will get into front end axle and tire capacity questions. Doing an automatic switch from shore-power, handling charging and selecting outlets to be powered is usually done by an Intellitec unit designed to do the complete job. Check their web site for several different models. Then what about providing a solar add-on in the future. You should certainly provide for this option.
My recommendation is to find a good dealer and let them design and install the system after you have provided the requirements. The hardware is expensive and will be the major cost component. If you are buying hardware almost all of the good shops will do the design at no cost. However, you will need wiring (including some very heavy duty cables), new fusing and a control panel that will require expertise. Trying to save a few bucks on labor may not really be cost effective.
I will be happy to help you select a vendor and also to review his design before you make the final purchase.
Howard
WBCCI Tech Help Group
Howard Lefkowitz is offline   Reply With Quote
Do I have an inverter? cmreumund Batteries, Univolts, Converters & Inverters 4 02-01-2009 08:10 AM
anyone have an inverter? safari25-05 Electrical - Systems, Generators, Batteries & Solar 10 01-20-2007 12:23 AM
What is an INVERTER woodedareas Electrical - Systems, Generators, Batteries & Solar 7 11-28-2006 12:37 PM
Inverter???? Kestrell General Motorhome Topics 12 06-18-2006 10:25 PM
inverter mlmarch Mechanics Corner - Engines, Transmission & More... 2 11-15-2004 11:36 AM
