Old 07-25-2012, 09:07 AM   #1
2005 26' Land Yacht Gas 26
Bedford , Nova Scotia
Intermittent Wipers?
Hi: I tried in the general motorhome section. Got several reads but no replies. So I will try here. The hesitation wipers on my 2002 26' LY often fail to hesitate but work OK on Slow or Fast. Does anyone know where the control module is. Workhorse don't know!.
Thanks.
Donald
DonaldW is offline   Reply With Quote
Old 07-25-2012, 10:56 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I checked the other thread, and I think you should give people more than 6 minutes to formulate a response before you give up on a thread and start another one.
On most of those units, the delay module, if that is what you are asking about, is mounted on the motor.
Old 07-25-2012, 11:01 AM   #3
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
GEE,
another misleading title.
I thought this would be about someone having a senior moment, sitting down in the bathroom and forgetting why he was there.
doorgunner is offline   Reply With Quote
Old 07-25-2012, 11:38 AM   #4
dznf0g's Avatar
Oswego , Illinois
I believe Overlander is correct. IIRC, remove the black plastic motor transmission cover and the board is attached to the underside of the cover.
-Rich-
Old 07-26-2012, 09:14 AM   #5
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
They may have changed, but my wiper control module is mounted right of the fuse box under the dash. Black box about 3"x3".
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 07-26-2012, 09:21 AM   #6
dznf0g's Avatar
Oswego , Illinois
Might call AS. Now that I think about it, they may not use the GM wiper assembly...and since Workhorse doesn't know (they do source a lot of GM componentry), I'd bet AS is sourcing them for the coach build, not workhorse at the chassis build. AS could be using anything from anywhere.
-Rich-
Old 07-27-2012, 03:45 AM   #7
Intermittent Wipers
Thank you people for the range of replies ranging from the anal to the useful. Contrary to opinion the control for the wipers is not on the motor as there are only three wires going to it as you would expect for self parking wipers. Additionally, the Workhorse wiring diagram also shows this. So the control unit has to be somewhere else. The large module beside the fuses I've pulled before and the wipers worked for a while. So now it is time to delve inside.
Thanks.
Donald
