Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 08-05-2016, 04:24 PM   #1
Pottsville , Pennsylvania
intermittent wipers
Hello, I have a 2004 Land Yacht 26ft motorhome. The wipers work, but the intermittent doesn't. Is there a fuse for this or a module. And were would the module be located. Your help is greatly appreciated. Thanks Rusty
Rusty4cyl is offline   Reply With Quote
Old 08-05-2016, 06:34 PM   #2
"Cloudsplitter"
Thumbs up Unless my grey cells have failed me...
Rusty,
Welcome Aboard.
....You most likely need the wiper pulse board.
Not positive if this is the proper P#, you can check with a Workhorse (Chevy) dealer.
The board is under the cover for the wiper motor.
Old 08-06-2016, 07:01 AM   #3
Thank You Sir. Nice to be here. The Chevy workhorse dealer, would that be a truck dealer ? I have a Chevy dealer here, but he said nothing comes up for a workhorse chassis. Thanks again Rusty
Old 08-06-2016, 11:56 AM   #4
"Cloudsplitter"
Thumbs up
Rusty,
Here are the Pa Workhorse dealers
The wiper motor fits a wide range of GM vehicles, the module should be available at quite a few Chevy stores if you can get the part#.
Old 08-07-2016, 04:16 PM   #5
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
At one point my wipers would only work on HI.....nothing less. Had started looking for a new switch cause I knew the motor and arms were okay. Fortunately my Dad (89 yrs old) was having a good day and in a discussion told me it was likely caused by lack of use. Told me to play with the switch with key off and moving it through all the setting. Guess what....it worked!!!
Mine has a round knob (similar to headlight switch) that turns for the delay feature and a slide switch with 4 positions. Hi...Low...delay.....Off
Mike1997 is offline   Reply With Quote
Old 08-20-2017, 12:08 PM   #6
My motorhome takes a pulse monitor that plugs in under the dash. I replaced that with a new one, but the intermitten wipers still don't work. The low and high speed work, but not the intermitten don't. Is it the wiper motor going bad. If it is, do they make a better one than what is on there. Your help is greatly appreciated. Thanks Rusty
Old 02-28-2019, 07:37 AM   #7
Dream Roper
DreamRoper's Avatar
2004 30' Land Yacht 30 SL
Fletcher , NC
Hey Rusty, I have a 30 ft 2004 land Yacht with the same issue.
Did you find anything more to solve your problem?
Thanks, Ron
DreamRoper is offline   Reply With Quote
Old 03-02-2019, 11:15 AM   #8
I took my airstream to a workhorse garage. They replaced intermittent module and wiper switch. It still didn't work, so they looked farther and found a clip that was turned over that shorted the intermittent, so they had to replace intermittent module and wiper switch the second time.And now they finally work. I hope this help's you Ron. Wasn't cheap, but they do work. Thanks Rusty
Old 03-03-2019, 10:29 AM   #9
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Hope they didn't charge you for the second switch and module. Seems kind of like they were just shotgunning the repair instead of trouble shooting it.
92landyacht is offline   Reply With Quote
Old 03-04-2019, 04:21 PM   #10
No I wasn't charged for the second ones. Thanks Rusty
Intermittent Wipers? DonaldW Land Yacht/Legacy Motorhomes 6 07-27-2012 03:45 AM
Windshield wipers tandemfish General Motorhome Topics 2 10-06-2004 07:56 PM
Windshield Wipers Running AccessMaster General Motorhome Topics 3 04-07-2003 07:15 PM
windshield wipers 350 LE classic 1992 dbyar Mechanics Corner - Engines, Transmission & More... 6 12-21-2002 11:56 AM
