Old 06-13-2015, 06:53 PM   #1
2000 31' Excella
Ontario , Canada
Insulation under the floor???
Hi folks.
Anyone know what is under the floor of the Land Yacht 30? Insulation?? how much? what is it? Covered underneath? Is it sealed or exposed to the elements?
woodytwo is offline   Reply With Quote
Old 06-13-2015, 09:44 PM   #2
1979 23' Safari
Wayland , New York
Insulation?? Roll unfaced Fiberglass insulation.
how much? Not much maybe 2 inches, but they lay it down then put the floor on top of it so it gets compressed between floor and frame and any metal frame components. Hangs down in between the spaces.
Covered underneath? Is it sealed or exposed to the elements? Only by the belly pan sheet metal. It tends to get pretty nasty down there after a while. Any water that does get into the belly the fiberglass likes to soak up like a sponge. Mice love to make cozy homes in it as well.
Old 06-14-2015, 11:48 AM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I recently drilled a 1" hole through my trunk. You have your wood flooring, 1" blue Styrofoam, wood again (I think) with flat sheets of aluminum sitting on the frame. Its about 2" thick total. I also recently gutted the rear bedroom walls and cabinets to repair water damaged laun and was surprised to find the entire top of the back end cap and all around both taillight housing has no insulation at all. So AS advertising full wall and ceiling and floor insulation is very misleading or untrue.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 06-15-2015, 01:54 PM   #4
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Yes, the same basic construction on my 92 LY. Flooring is wood OSB then about 1.5" of the same blue Styrofoam insulation as in the walls. I had a significant section of flooring that was damaged from water so I had to cut it out and replace the OSB. Got a real good lock at how it was constructed.
There are some pics in this thread:
http://www.airforums.com/forums/f312...es-102148.html
92landyacht is offline   Reply With Quote
Old 06-15-2015, 04:57 PM   #5
1979 23' Safari
Wayland , New York
Sorry, on phone couldn't see it was a motor coach instead of a TT.
Insulation under the floor vanster Repairing/Replacing Floor &/or Frame 7 03-06-2015 07:57 AM
Under floor insulation? colin57 Repairing/Replacing Floor &/or Frame 10 05-02-2011 02:15 PM
What insulation did you use under the floor? adwriter73 Repairing/Replacing Floor &/or Frame 32 03-04-2010 08:01 AM
Should there be insulation under the floor? rlindberg Interior Restoration Forum 9 05-18-2009 11:10 AM
Under floor insulation Rick Alston Repairing/Replacing Floor &/or Frame 18 01-26-2004 08:02 PM
