Old 01-08-2012, 04:00 PM   #1
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
HWH level sensor location
Anyone know where the level sensor for the HWH leveler system is located on a 92 36' LY? I have the HWH 610 series system and it seems like the sensor has been mounted 180 degrees out of position, but I dont know where it it.
92landyacht is offline   Reply With Quote
Old 01-08-2012, 08:22 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
On my Clipper the master brain box is located in the main compartment between the frame rails, mounted forward of the fresh water tank on the ceiling of the compartent. All the fuses are in that box.
The Clipper has the Power Gear system on it, but I would think Airstream might use a common approach to mount the different equipment.
Dave
Old 01-09-2012, 09:44 PM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
On my 93LY its located under the coach,on the metal sub flooring,just inside the rail, right side a little forward of the back tires. I have the automatic self levers. Also I looked in manual and couldn't find any statement that the engine has to be turned off to operate system.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 01-10-2012, 08:35 PM   #4
1992 36' Land Yacht
Grayson , Georgia
Thanks Gloran. That's exactly where it is on mine. I looked and cound a disked shaped thingamabob that could be be the sensor. Thanks for the help!
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
HWH Leveller - where is the 15 amp fuse? Boom Sounds Mechanics Corner - Engines, Transmission & More... 3 09-22-2011 07:14 PM
How to measure to get Trailer and Tow Vehicle level Airperson Towing, Tow Vehicles & Hitches 11 08-24-2011 05:45 AM
Tank Level Sensor - Just Learned Something AirsDream Plumbing - Systems & Fixtures 3 06-26-2011 04:15 PM
Bypass for HWH Desikk Land Yacht/Legacy Motorhomes 3 06-03-2011 05:29 AM
