Old 09-12-2014, 11:52 AM   #1
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
HVAC problems
I have a 1994 Land Yacht Legacy 34. At the beginning of a day's drive, the heater and AC seem to work just fine. As the miles and the day wsears on, and especially if we're doing multi day trips, the amount of air coming out gets less and less, down to zero/zilch/nada, I can still hear the fan blowing though. This seems to be a distribution problem, because there is both cool AC air and hot air at the start of any day.
I should emphasize that I am talking about the dash air and heat.
Punch is offline   Reply With Quote
Old 09-12-2014, 12:04 PM   #2
Your describing a freeze up situation.
As you dash air keeps working, it's slowly building up some ice that gets in the way of the air.
The usual problem is a dirty air filter, as not enough air is crossing the cooling coils.
Old 09-12-2014, 12:35 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Another problem that can cause the evaporator coil to freeze up on longer trips is low refrigerant levels.
— David
Old 09-12-2014, 12:59 PM   #4
Rivet Loser
Punch's Avatar
Thanks both. But this occurs if the AC is off and I'm just on heat too. Woould I still get freeze up?
Andy...... air filter? What air filter?
Old 09-12-2014, 02:03 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
So, you don't get air output from ANY vents (floor, dash, windshield) when this is happening, but you're sure the fan is still turning at normal speeds? Depending on how the distribution is controlled, it might be a servo problem but I'd expect the air to always go SOMEWHERE, the distribution controls should affect where, but not be able to turn it off (in most automotive systems... I've no experience with the moho system specifically.)
— David
Old 09-12-2014, 02:05 PM   #6
1974 Argosy 20
Kooskia , Idaho
Yes, because the air first goes through the cooling part of the system to dehumidify it, then to the heater section to warm it up so it is warm and dry. So, freeze up can happen even when using heat.
Old 09-12-2014, 05:11 PM   #7
Rivet Loser
Punch's Avatar
Thanks David and idroba.... I can still hear the fan blowing away, but I don't get air coming out, at least not to feet and face, although I'm not sure about windshield. At first, at the beginning of a run, all is normal, but then after a while, maybe an hour or two, I have to move the control to Max in order to get flow, then that slows and eventually all air flow seems to stop, but I can still hear the fan blowing somewhere just as strongly.
Thaks for the clarification, idroba. I guess I need to find where the air filter is.... under hood or in front of passenger seat maybe?
Edit: this thread
http://forums.trailerlife.com/Index....d/25390449.cfm
..... seems to indicate that the consensus is there is no such thing as a dash air filter?
My initial thought was whether I had some kind of progressive vacuum leak that for some reason got worse over time, but then disappeared by a new day, something heating up then leaking? I have no idea what I'm talking aboput though.
Old 09-12-2014, 05:24 PM   #8
1974 Argosy 20
Kooskia , Idaho
I am pretty sure your coils are freezing up. When it happens again, try turning the system off for a while (maybe half hour) and then re starting it. If it now blows air, what has happened is that the coils unfroze and air flow is resumed.
You probably will need service. The possibilities are low refrigerant or a defective pressure control which does not shut the compressor down at the right temperature. There are no air filters in the old system you have which would cause the problem.
Most AC repair shops will understand what is going on if you explain it to them, and will be able to find the issue. It is pretty common. Even my 2012 Jeep Grand Cherokee has the issue now and then, and I need to have the thing repaired under warrantee.
Old 09-12-2014, 05:39 PM   #9
Rivet Loser
Punch's Avatar
Thanks idroba, I shall take it to a different shop than the last one, since they couldn't find why my heater wasn't working, and I then found it was because the cable had disconnected at the dash control end! The trouble is finding someone competent and honest.
Old 09-14-2014, 05:31 PM   #10
2000 31' Excella
Ontario , Canada
Smile You have to appreciate this guy!
Hi Andy. It is so good to see your input on the Airstream Forums. I have owned 3 a/s trailers and now a LY 30 M/H. Your inut has always been most valuble and appreciated over the last 15 years. Thank you and keep the info coming.
Woodytwo
woodytwo is offline   Reply With Quote
Old 09-21-2014, 09:22 PM   #11
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Had a similar problem in my classic, and affected both heating and cooling. It turned out to be a bad grounding cable for the dash fan. Specifically, the gauge wire was too small for the ground, it would get very hot, and over time the thermal buildup would kill the voltage to the motor and therefore the airflow, but the fan still sounded like it was running. Recommend checking your grounding wire. If it is an 18-14 gauge wire, recommend changing to an eight to ten gauge.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
HVAC thermostat opinions please! AtomicNo13 Electrical - Systems, Generators, Batteries & Solar 8 07-10-2012 04:08 PM
HVAC Experts-Please Help tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-03-2012 07:50 PM
Help an HVAC noobie out... can I combine the furnace and A/C t-stat? Taylormade Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-16-2012 02:13 PM
Generator--HVAC Question Tideair Generators & Solar Power 10 03-14-2012 09:24 PM
Airstream - Free Standing HVAC anglev Winter Living 8 12-04-2011 07:20 AM
