Old 02-23-2015, 05:50 PM   #1
2004 26' Land Yacht Gas 26
downey , California
How do I replace the water pump in 2004 Land Yacht?
When pump is turned on it pumps water out the shore water fill inlet? Some water also comes out the faucets but pump only momentairly shuts off then continues to gush water out the filler port. This pump is buried behind cabinets and boxed in by the cabinets. Anyone ever changed one? What's happening? It's an Aerojet pump.
Thanks Chuck
cfanna is offline   Reply With Quote
Old 02-23-2015, 06:13 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
how do i replace the water pump in 2004 land yacht
Is it the water fill port or the city water connection? If it's the city water connection.
It's not the pump. It's the check valve in the city water fill connection. If you have the type which connects to a hose. Put a cap or plug on/in it.
Old 02-23-2015, 06:24 PM   #3
2007 22' International CCD
Look into the port the water gushed out of and see if there is something jamming the check valve disc open. It's not the pump. The check valve in the city water connector is stuck open or damaged. That's probably a lot cheaper than the pump, which sounds like it's working fine.
KE4GNK/AE
Old 02-23-2015, 06:41 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I have seen foreign material get caught in the one way valve just inside the city water inlet. Hooking up to the city water and running water through that valve may solve the problem. A threaded plug will also keep the water from coming out of the inlet, but that will not solve the problem. Last fall I had to replace the inlet/one-way valve on our '65 Caravel. The spring and other small parts came out and could not be re-inserted.
Your pump is OK.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 02-24-2015, 01:22 PM   #5
2003 26' Land Yacht 26
Redmond , Oregon
I also just got an 03 Land Yacht but without any manuals--could you please respond to my note here by e-mail so I can discuss the manuals--thank you--mike
mhardin71 is offline   Reply With Quote
Old 02-24-2015, 01:23 PM   #6
Redmond , Oregon
forgot my e-mail--mhardin71@yahoo.com--thanks
Old 04-06-2015, 03:40 PM   #7
downey , California
Fixed inlet check valve ok Now pump just hums & no water flows
How do I get access to work on pump, it's buries behind cabinet at floor level ?
Old 05-18-2015, 07:58 AM   #8
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Our water pump and the check valve are both just inside the coach from the fill door on the exterior of the coach. It's beneath the seat of the dinette, behind the pull out drawer. It's accessible by taking the cushions off and removing the wood that supports the seat cushion. Once you get there you can see the entire incoming water system, both city water and hose fill for you tank with the check valve and pump. Replacing the pump involves 3 screws a a few hose clamps and wire connections. A good do-it -yourself project.
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 05-20-2015, 09:07 AM   #9
pvmsteve's Avatar
2004 30' Land Yacht 30 SL
Overland , Missouri
Water pump
The water pump on mine 30' LY ,2004 can be changed though the door on the floor. The inlet and outlet comes off by moving clips to the right and releasing the hose. The elec. will be removed, taking care to note the location ofvthe wires.
pvmsteve is offline   Reply With Quote
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
When to replace the water heater? (original 2004 unit) lbdesign Water Heaters, Filters & Pumps 16 03-14-2013 06:50 AM
'04 Land Yacht MH Water Pump Problem RAG Land Yacht/Legacy Motorhomes 18 08-08-2012 06:11 AM
wiring for water pump on '62 land yacht farmsc 1959-69 Tradewind 15 08-14-2008 09:05 PM
Water Pump - 2004 Classic jcanavera 2001 - 2005 Classic 12 06-26-2004 09:56 PM
