Old 05-09-2013, 05:13 AM   #1
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
How do I remove these streaks?
I have used strong cleaner and cannot remove these streaks.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 05-09-2013, 06:05 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I've used these 3M products over the years with very good results.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 05-09-2013, 06:51 AM   #3
2000 31' Land Yacht
Fort Erie , Ontario
Try bar keepers friend and magic eraser and elbow grease. This is part of the prep for putting on RedMaxPro. Can search for that on this site.
Steve
is.chowa is offline   Reply With Quote
Old 05-09-2013, 07:30 AM   #4
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Pretty sure you're going to have to strip it to get those streaks off. On mine I did the Bar Keepers Friend using a 3M no scratch pad and then covered everything with the Red Max Pro. Mine had no shine at all when I bought it so I had nothing to loose. A year later it still looks great with lots of shine.
92landyacht is offline   Reply With Quote
Old 05-09-2013, 10:45 AM   #5
2012 25' Flying Cloud
Tacoma , Washington
Is Bar keepers Friend and Bon Ami the same type of product ?
BigGrey is offline   Reply With Quote
Old 05-09-2013, 11:05 AM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I think Barkeepers Friend has a small amount oxalic acid in it - which removes rust stains and cuts through water stains too. There used to be another product called "ZUD" which was really a great rust remover, but I haven't seen it in years. I used to live in a house with high iron well water and the toilet bowl was brick red under the water line. I tried everything. My boyfriend tried everything including steel wool... and couldn't cut through it. I brought home a can of ZUD on a friend's recommendation, sprinkled it into the bowl and literally watched it work like bleach. If you find it, let us all know where.
Bon Ami doesn't scratch, but I don't think it works quite as well on rusty streaks.
Paula
Old 05-09-2013, 11:10 AM   #7
Tacoma , Washington
Thank You Paula
Old 05-09-2013, 11:25 AM   #8
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I am using rubbing compound to the sides and the front just the back I'm worried about getting the streaks out
Old 05-09-2013, 12:59 PM   #9
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Try Scrubbing bubbles bathroom cleaner with a nylon brush.This stuff works magic on carpet,vinyl,plastic etc.I have been using it on Ferrari's and Lamborghini's for 20 years.
Old 05-09-2013, 01:02 PM   #10
Moflash's Avatar
If the Scrubbing Bubbles does not work on a small test area a Detail shop can use 3M finesse with a buffer on low speed and remove the streaks.
Old 05-09-2013, 01:46 PM   #11
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I just got some 3M rubbing fine/med compound. I am going to do the light grey this evening except for the rear(where the streaks are). The lower dark grey came out with a high shine with elbow grease and Liquid Glass. I was going the use orbital polisher as I am afraid i'll loosen the decals with a buffer.
Old 05-09-2013, 02:12 PM   #12
reinergirl's Avatar
Hollis , New Hampshire
Paula
I still get Zud at my local Aubuchon Hardware. Like this? I like it too...
Zud Rust & Stain Remover (00750) at Aubuchon Hardware
reinergirl is offline   Reply With Quote
Old 05-09-2013, 02:12 PM   #13
Moflash's Avatar
Rubbing compound is pretty harsh 3M finesse is much,much more fine.Use masking tape and tape off the decals.
Old 05-09-2013, 02:35 PM   #14
dznf0g's Avatar
Oswego , Illinois
Use in a hidden area first....disclaimer over. On my old SOB I used Wesley's Bleach White on ABS and plastic exterior components for 17 years without damage. It removes all kinds of streaking well. Don't leave it on for any longer than it takes to scrub...rinse immediately.
-Rich-
