Old 05-09-2013, 02:03 PM   #15
toastie's Avatar
1955 22' Safari
Great Lake State , .
Gel Gloss
Tr Industries Gel Gloss One Step Cleaner and Polish: Household Essentials : Walmart.com
http://www.campingworld.com/shopping...er-quart/18002
also home depot, camping world sell it in there store
toastie
toastie is offline   Reply With Quote
Old 05-10-2013, 05:21 AM   #16
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
Those streaks aren't coming out. I can get them faded with rubbing compound a little but thats it.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 05-10-2013, 05:30 AM   #17
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Is the panel plastic/composite?
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-10-2013, 05:34 AM   #18
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I think that Bar Keeper’s Friend could be an easier alternative to rubbing compound. Any thoughts? I think I'm running out of elbow grease.
Old 05-10-2013, 05:44 AM   #19
Thumbs up
Originally Posted by wvabeer View Post
I think that Bar Keeperís Friend could be an easier alternative to rubbing compound. Any thoughts? I think I'm running out of elbow grease.
Maybe if your drunk.......
Anything is worth a try, but compound should be more aggressive than BKF.
Sounds like the stain has penetrated thru the top layer. Thats where a top dressing may help. Give it a swipe with WD40 just for s&g.
PFC
RLC
Old 05-10-2013, 06:57 AM   #20
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Like I said, you're going to have to strip it first and then recoat. My guess is that a PO has used something like Red Max Pro. Try an ammonia floor stripper in a small area to see if it can remove it. If so then clean the entire area with it and then recoat. If it's till the original clear coat then the ammonia wont effect it.
92landyacht is offline   Reply With Quote
Old 05-10-2013, 07:26 AM   #21
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I don't think thereis a clearcoat I would have went thru it with scotchbright
Old 05-10-2013, 04:39 PM   #22
1992 36' Land Yacht
Grayson , Georgia
Not really. The Red Max is pretty tough stuff. I used a Brillo pad and couldn't get through it. Like I said, if the ammonia floor stripper removes it then you know its been coated. Since you don't really know the history of your unit I'd try it in a small area and see what happens.
Old 05-11-2013, 06:32 AM   #23
2000 31' Land Yacht
Fort Erie , Ontario
I would use TSP Tri Sodium Phosphate to strip it. If a coating such as RedMaxPro was applied over stains then the stains would be sealed in, so stripping is a good idea. I believe that RedMax also produces a "remover" which may be the way to go. As always, try it on a small area as noted previously.
Steve
is.chowa is offline   Reply With Quote
Old 05-11-2013, 06:14 PM   #24
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Got it all rubbed out
After 7 hours of Rubbing compound and a new wool pad for my buffer and alot of elbow grease, it ready for Liquid glass polish/finish . I now know the color is light gray and matches the driver door now. Notice the streaks are gone. How do you get to the top of the windshield to polish, any ideas?
ID:	185580   Click image for larger version
ID:	185582   Click image for larger version
Old 05-11-2013, 06:48 PM   #25
Myrtle Beach SC
2011 19' Victorinox
chester , Virginia
Go to the dollar store and get you a bottle of Awesome. This stuff is great. Removes black streaks form campers and also will work wonders on your gutters at home.
Victorinox is offline   Reply With Quote
Old 05-11-2013, 07:06 PM   #26
1992 36' Land Yacht
Grayson , Georgia
I leaned a 6' ladder against 2 foot 2/4 wood boards between the ladder and the glass to polish the top end cap. I know it sounds dangerous, but it really doesn't put that much stress on the glass if you use long the boards to distribute the weight and angle the ladder at the same angle as the glass. Most of the weight is actually directed down.
What happened to your turn signals?
Old 05-11-2013, 07:16 PM   #27
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
They needed cleaned/sealed up, they were dirty and yellow with moister behind them
Old 05-12-2013, 02:58 PM   #28
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Here with tje lights all cleaned up.
