Old 03-03-2009, 10:49 PM   #15
1990 33' Land Yacht
Jacksonville , Florida
gloran,
Thanks. I'm presuming that for whatever reason, AS changed the electrical system component locations. As I stated in an earlier post, my AC/DC distribution panel is located under the left side of the sink, which in 1990 was on the street side of the MH.
Your galley is on the curb side, I believe.
My house batteries are located under the step at the entrance door. Where are yours?
Safe travels,
FRank
Frank and Susan Davis
Jacksonville, Florida
33' 1990 Airstream Land Yacht: Edelbrock, Banks, Gear Vendors, MSD, Taylor wires, Super Steer bell cranks, Bilsteins, Roadmaster sway bar, Safe Steer, Pressure Pro, Crossfire, Bigfoot levelers, Rickson 7.5" rims & 245/70 R19.5 Bridgestones on steer axle.
Taxman is offline   Reply With Quote
Old 03-04-2009, 07:15 AM   #16
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Smile converter and inverter location
Originally Posted by gloran View Post
Frank, on my 33' the converter is behind the carpeted panel under the dash, in front of the front passenger seat. The outlet sets right beside the converter,both are mounted on the right side wall.
Thanks, my thirty does have the carpeted panel, and found the two screws to take it off, they were buried in the carpet. Tv is plugged into the inverter in the same area.
Dave
Old 03-04-2009, 08:56 PM   #17
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Frank, All my batteries are located under the hood left side,two house and the one coach.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 03-04-2009, 09:50 PM   #18
1990 33' Land Yacht
gloran,
I guessed as much. That explains why your converter/charger is in the front of your coach.
Does anyone know if the Xantrex XADC converter/charger will fit in the space the Magnetek 7345 occupies? Dimensions are very close.
Thanks to all for their help and insight re: my charger/converter.
FRank
Old 03-17-2009, 06:48 PM   #19
gunworks's Avatar
1995 35' Land Yacht Diesel
Noblesville , Indiana
Frank,
I installed a Xantrex (2.0) last summer and while they are similar in size, the Xantrex needs much more free flow of air. I posted pics on here back in the fall. I love this system and all battery problems have been eliminated. Just make sure there's no restriction on air flow and use minimum of 2/0 cables and minimal length runs to batteries. I can send you a quick install sheet if you like to decide if you want to go this route.
John
penworks2@juno.com
95 Landyacht
gunworks is offline   Reply With Quote
Old 03-23-2009, 12:21 PM   #20
1990 33' Land Yacht
Gunworks,
Thanks. I'd very much appreciate a copy of your install sheet. Email to fdavis03@earthlink/.net, please.
Safe travels,
FRank
Old 03-23-2009, 04:14 PM   #21
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Taxman, did you ever find out if the Parallax can be converted to a three stage charger?
I have a solar panel with a three stage charger, so I just let that keep the batteries charged. I don't plug in shore power while at home unless the panel has been snow covered for a long time or I want to cool down the refrigerator. But when at a RV campground, I would think the shore power there may be overcharging the batteries.
Gene
Old 03-26-2009, 09:37 PM   #22
1990 33' Land Yacht
Gene,
The Magnatek cannot be converted, dadgummit!
On our trip to the Everglades, I checked the converter output -- steady 13.8 volts on shore power. Will buy/install a Xantrex three stage converter before we leave on our summer trip.
Safe Travels,
FRank
Old 05-01-2009, 07:41 AM   #23
1990 33' Land Yacht
Update: Installed IntelliPower 9260 before most recent weekend trip.
All is well!
Chassis/House Battery Charging 4 Motorhomes Jim Tyrney Airstream Motorhome Forums 41 03-11-2011 06:50 PM
Interstate house battery change EIDAM3 Sprinter and B-van Forum 5 07-13-2009 10:14 AM
Master Battery disconnect FishByFly Batteries, Univolts, Converters & Inverters 7 11-20-2007 05:53 PM
House battery types ralley Electrical - Systems, Generators, Batteries & Solar 12 02-13-2006 08:18 PM
master kill switch Deborah V Our Community 6 09-06-2004 07:43 AM
