Old 10-23-2012, 08:11 AM   #1
pol
1995 30' Limited
1995 31' Land Yacht LE
Seattle , Washington
Lightbulb Hot water switch
The switch is in the bath. There is a four slot plate - only two are functional - one is the switch, the other is the light. This morning I noticed an opening at the top of the plastic toggle (I can see copper) - it does not appear broken or melted. The switch clicks up and down, but the heater no longer lights. I am not out of LP.
Any thoughts?
pol is offline   Reply With Quote
Old 10-23-2012, 08:37 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the switch is making contact you should hear the igniter at the heater clicking and the red light should be on until the heater is light.
If not remove the cover and check for 12 volts at the switch. If the switch is open you should have power on one side. Any metal on the trailer body should act as a ground for these checks. If not check the fuses. If the switch is made and you have power on both sides the wire to the heater may be broken or the limit switches may be bad. If you have power on both sides go to the heater and check for voltage at the the limits switches. They are the 2 small round dime size items attached to the side of the heater, red wires. You should have power on all 4 connections. If you have power on only 1,2 or 3, of them the one you do not have power across is bad. If all 4 have power and the heater is not attempting to come on the control may be bad.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 10-31-2012, 06:11 PM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Check this thread - from my experience http://www.airforums.com/forums/f44/...ml#post1182010
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
