Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 11-12-2007, 08:10 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Horn blows unintentionally
I have a 2003 AS LY Gas. Last night 2:00 AM, I was awaken with the horn blowing constantly. Scared the h--- out of me and DW and dog. I quickly pulled the fuse. Has this happend to anyone else. Any thoughts whay may have caused this delima? In 70 years of life, this is a first for me. Thanks.
Steve
spat61 is offline   Reply With Quote
Old 11-12-2007, 08:55 AM   #2
RBolton's Avatar
Belington , West Virginia
Steve, I can't give you any specific AS advice but generally a problem such as this ends up being either a faulty horn relay or bad horn switch. Sometimes these are affected by changes in temperatures.
RBolton is offline   Reply With Quote
Old 11-12-2007, 09:34 AM   #3
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Me too...
This will occasionaly happen to me depending what I've eaten...
Sorry, couldn't resist.
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 11-12-2007, 10:19 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Steve
Are you interested in troble shooting this proble yourself? In which case I will post a trouble shooting procedure.
If not you will need a shop that understands auto electric, Not An Easy Find.
2004 Excursion 4x4
Old 11-12-2007, 10:28 AM   #5
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Your rig has Tootetts syndrome
Michael
ArtStream is offline   Reply With Quote
Old 11-12-2007, 05:34 PM   #6
richinny's Avatar
2011 34' Classic
Westchester Cty.NY , / Miami FL
i've had cars do that in very cold weather. it might be caused be shrinking or expansion in the horn button. if you disconnect the trigger wire and it stops, the problem is between the button and your disconnect point. just note that if you just disconnect the horn, (i know you pulled the fuse, so it doesn't apply to you) the relay will still be activated and drawing power.
Ricky
richinny is offline   Reply With Quote
Old 11-13-2007, 09:34 PM   #7
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
I had this happen on a truck,
The horn that you push on might be bent / out of square.
The metal contacts seem to be bent, and blew the fuse . I pulled the switch off the steering wheel and just bent it back in place
Worked for me.
Rob
myfirstrv is offline   Reply With Quote
Old 11-14-2007, 05:51 PM   #8
spat61's Avatar
Horn blowing without human intervention
Here is my dilema. At 02:00 AM my horn started blowing steady. I was not fully awake and in my stupor I smacked the steering wheel. It stopped.
I then pulled the fuse in case it wants a repeat and the neighbors call the cops on me. I can't put the fuse back because I don't know if it will repeat and I can't take that chance that it won't.
I understand it may require removal of the horn ring. Has anyone had this experience? Does anyone know the steps for removing the horn ring and steering wheel because I'm thinking I would like to repair this condition myself. That $95.00 per hour stuff is hard on the wallet. BTW, this is a 2002 AS LY (Gas) Thank you.
Steve
Old 11-14-2007, 06:33 PM   #9
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Back in my old VW days that used to be a problem. if I remember correctly the wire ran down the steering column, right through the middle and if it shorted out (went to ground completing the circuit) the horn would go off. I don't know if that is the same problem you have. But have you been able to look closer at why it went off in the first place? Loose bushing or plastic insulator???
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 11-14-2007, 08:32 PM   #10
InspectorDread's Avatar
1987 34' Excella
Mobile , Alabama
Call TAPS. They will come and investigate your paranormal problem. And while they are there, they can handle all of your plumbing problems(ROTO-ROOTER)
InspectorDread is offline   Reply With Quote
Old 11-18-2007, 09:33 PM   #11
myfirstrv's Avatar
Vermilion , Ohio
Steve,
To explain better, my horn was bet, out of square, out of plum
it was in the steering wheel,
I drove this thing from 51 miles till 149,000 miles and never knew --some how I bent . pushed too hard , pushed out of square the horn.
so I pulled everything and looked at it at "rest" So when the horn is sprung up/ "at rest", the contacts should not touch, if a contact touches the ground, then something is not lined up right.
keep looking at it NOT as you took it apart but as it might work correctly,
good luck
Rob
Old 11-19-2007, 08:15 AM   #12
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
I don't know what type of horn button you have on your LY, but my '96 Dodge has a thumb button on each side of the steering wheel. The right side tends to hang up when pressed. A couple of weeks ago, just as the sun reached the interior, the horn magically sounded loud and long. Fortunately I was only a few feet away in the trailer and used my great technical skills to remedy the situation-- I hit the right side of the wheel really hard with the heel of my hand. I assume that after a cold night, as the sun hit the wheel the expansion caused the contact. I keep intending to clean it up and apply some silicone spray lube, but when it isn't a problem I tend to forget it. I'm writing myself a reminder before I send this!
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 11-19-2007, 08:53 AM   #13
HowieE's Avatar
Images: 12
Who's chassic is the motor home on? The horn and it's related components were installed by the chassic manufacture. If you post the manufacture I may have wireing diagrams.
2004 Excursion 4x4
Newbie needs help with broken horn hince57 General Motorhome Topics 2 09-15-2007 08:18 PM
Horn doesn't work! Astrodokk Classic Motorhomes 9 10-22-2006 07:14 AM
Air Horn repair smily Classic Motorhomes 2 07-28-2005 07:38 AM
A/C Blows GFI in Home Jenturnr Our Community 3 07-27-2004 07:39 PM
Re: Horn 2nd query Orland Dewey General Motorhome Topics 14 07-11-2003 02:19 PM
