Old 01-12-2016, 05:32 PM   #1
2004 30' Land Yacht Gas 30
Langley , British Columbia
Help with step please
Hello, We have a 2004 Land Yacht gas motorhome, 31'. Our front door blew off the door closing piston in the wind about one year ago. We had it repaired by a handyman but then the door opened completely up so it swung right up against the passenger seat frame.
We fixed the door (or at least we thought we did haha) by replacing the piston, but the piston was a bit too big and it bent the door frame a bit a the bottom. When the door is closed there is a bit of a warp to it.
Now the automatic step that opens and closes when the door does will not stay under the rig when we are driving. We turn off the step by the panel switch just inside the door but it does not keep the step under.
So when we are driving the step just keeps going in and out of its own accord.
We have been hesitant to strap the step under in case we burn out the motor.
We cannot find the fuse for the step - my husband has looked everywhere.
My nerves are shot and we both feel like idiots.
We are in the middle of a trip right now and would just like to disengage the step. Any ideas???? Thanks, Shelagh
shelagh is offline   Reply With Quote
Old 01-16-2016, 06:56 AM   #2
Bikerman's Avatar
1989 34.5' Airstream 345
Palm Harbor , Florida
Hi, I had a similar problem, I understand the frustration. I had to go underneath the rig and find the electrical plug to the motor. With the step in the desired position I unplugged the motor connector to keep the steps locked in that position. That was temporary until I reached my destination then troubleshot the problem. If your door frame was bent it may be causing the activation switch to be pushed when it shouldn't be.
Bikerman is offline   Reply With Quote
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
Step-by-step sewing an awning yukionna Awnings 11 12-28-2006 01:37 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
