Old 05-30-2014, 05:02 PM   #1
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Heat and A/C question P-30 chassis
Put in new antifreeze and while checking system by putting on the heat to circulate the fluids, saw a leak out of dash a/c over the battery, checked freon lines going into it and they were cold, and sweating. The leak turned out to be condensate. Question is why is the a/c on when switched to heat and working hard to remove humidity from 85 degree air? Is it normal for a/c to be on when dash switch shows heat position?
Old 05-30-2014, 05:26 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Can't speak for sure about your coach but many cars run the A/C with the defroster to clear the wind shield. Is you defroster switch partially on?
Cheers, Dan
~ Margaret Thatcher ~
Old 05-30-2014, 07:16 PM   #3
1974 Argosy 20
Kooskia , Idaho
In general on many automotive systems, the cooling side works, and the heating side works, and a blend door mixes hot and cold air to achieve the desired temperature. In addition to reduce humidity and window fogging, all air is first run through the cold side to dehumidify it. So, what you have seen is normal for how the systems were designed.
Old 05-31-2014, 09:17 AM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Originally Posted by idroba View Post
blend door mixes hot and cold air .
Checked dash switch, on include a setting for floor, mix, or defrost.
I had put it on mix thinking it was above defrost and not using a/c didn't know about the blending using it.
thanks
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
quality of airstream and especially chassis in 70's and 80's turfclubroad Our Community 1 05-21-2009 06:37 AM
GAS GAUGE / FUEL TANK QUESTION - P-30 Chassis N2XBW Classic Motorhomes 8 12-18-2007 08:38 AM
