Old 10-13-2013, 12:44 PM   #1
2000 35' Land Yacht XL w/slide
pagosa springs , Colorado
Hazard Lights Flasher
I'm stymied. I have a 2000 Land Yacht 350 on a Ford Triton chassis and the hazard lights don't work. Both turn signals work fine but no hazard lights. I've looked everyplace I can think of for the flasher unit, any ideas?
Thanks Much
wmd1931
wmd1931 is offline   Reply With Quote
Old 10-13-2013, 06:09 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Not sure but it may be in the fuse/power box under the hood, IIRC that is where it is on my heavy Ford trucks. I do know that it is a separate flasher from the turn signal on some of them. Another thing to check might be the fuse too.
Aaron
WBCCI #XXXX AIR #2495
Old 10-14-2013, 10:17 AM   #3
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
Multi-Function Switch Harness Connector
When my hazard flashers stopped working it was the Multi-Function Switch Harness Connector on the steering column. This connector has a history of overheating and melting.
I bought the connector and replaced it myself. The dealership wanted a fortune for the parts and labor.
The part is available from ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners
BarnacleBill is offline   Reply With Quote
Old 10-14-2013, 10:46 AM   #4
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . what I usually do on such things automotive is go buy a new one & then, once in hand, search for it on vehicle. Has worked well for flashers, relay type stuff in past, just don't know if that's a part you can buy in a 'parts store', regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
