Old 04-22-2015, 05:15 PM   #1
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
Gettin' ready for Spring
So far.. Pulled fuel tank changed pump & filters & cleaned out tank. Had a leak in curbside rear jack, replaced oring in lowering slave cyl & full press test. Weeping leak from assy weld on shell. Grind & reweld & test ok. Water heater had what's called a Hott Rod? Said rod shorted, blasted a hole in heat exchanger in tank. Tanks leaks. Order & replace tank (PIA until you figure out the collars). Now on to repairing trim & resealing roof & windows, installing stereo w/back up camera & remaking bumper on Jeep TJ to tow! Fun.
garypk is offline   Reply With Quote
Gettin ready for our first camp out and I've got a question 386kustoms On The Road... 6 06-15-2012 07:55 AM
gettin started angelapratt Ribs, Skins & Rivets 5 11-03-2009 09:34 AM
Gettin' Hitched! Boondocker Hitches, Couplers & Balls 52 11-20-2007 10:13 AM
Gettin to de roof Iver Full-Timing 8 03-10-2007 07:08 PM
Accel Extreme Heat 9000 Wires R Not gettin' it! ALANSD Mechanics Corner - Engines, Transmission & More... 6 11-06-2004 05:26 PM
