Old 09-19-2012, 05:15 PM   #1
1998 31' Land Yacht
Lake Odessa , Michigan
Generator Stopped running
I have the onan bgm gas generator. Does the generator run off the main fuel tank and does it have to be at a certain level to work?
btuinstra is offline   Reply With Quote
Old 09-19-2012, 07:26 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Yes, the separate Generator Tube only goes 3/4 down the tank. At least thats how its set up on the 80/90 classics
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-20-2012, 05:51 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Makes sense. That way, your generator can't leave you stranded; even when the generator quits, you still have a quarter-tank to get you back on the road to go buy more fuel.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-20-2012, 06:38 AM   #4
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
Ditto, on my 2004 Land Yacht.
RAG is offline   Reply With Quote
Old 09-20-2012, 06:40 AM   #5
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Yep, pretty much the same on every motorhome I've been in.
92landyacht is offline   Reply With Quote
Old 09-20-2012, 07:24 AM   #6
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
Did you get a Fault Code?
The indicator light will repeatedly blink 3 blinks or 4 blinks at a time. Count the blinks. There will be a little pause between the two numbers.
A Code 36 is a Engine stopped without command by controller fault.
If you are under 1/4 tank of gas that could be the problem.
BarnacleBill is offline   Reply With Quote
Old 09-20-2012, 08:58 AM   #7
Gainesville , Florida
generator low on oil? Jim
