Old 08-19-2015, 03:16 PM   #1
2000 31' Excella
Ontario , Canada
Gas nozzle keeps shutting off when filling tank
Not sure if it is a problem needing to be fixed or ?????. But sure is frustrating. When filling my gas tank I have to have the gas nozzle set to slow or very slow or the gas nozzle does an auto shut off. Is this just my m/h or do others have this problem as well? If it is only my m/h with this problem, what the fix?
woody
2005 LY 30
woodytwo is offline   Reply With Quote
Old 08-19-2015, 03:43 PM   #2
2007 22' International CCD
Check for obstructed air vent in your fuel tank or immediate connections to it. Had that issue in a car with a twisted vent hose. Fuel signed up in the full tub instead of venting air out to the top of the fill tube where the gas nozzle can vent air out. Look for a crimp in a hose.
KE4GNK/AE
Old 08-19-2015, 03:54 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
It is the nozzle not your vehicle. Let the attendant know about it.
MICHAEL
Old 08-19-2015, 04:01 PM   #4
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
gas nozzle keeps shutting off when filling tank
Most of the older MH do it. The original tanks weren't vented and used a vented cap....
There are several threads in it and I chased for a while thinking it was a kinked filler pipe. Modern pumps just plane deliver too fast for old non-vented tanks
martin300662 is offline   Reply With Quote
Old 08-19-2015, 04:04 PM   #5
richinny's Avatar
2011 34' Classic
it might have an anti-siphon spring in the fill tube to prevent fuel theft.
Ricky
Old 08-19-2015, 04:37 PM   #6
Mission , Texas
Both my F250 and RAV4 do the same thing. The F250 is mostly diesel bubbles in a crooked tank filler neck. The RAV4 is all crooked tank filler neck, about of the 1/8 tanks worth.
nrgtrakr is offline   Reply With Quote
Old 08-19-2015, 05:27 PM   #7
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
gas
Mine is older than yours & it doesn't ever do it. Nor should it. if it happens at different pumps, look for a kink in the filler hose or maybe a clogged vent . Does it happen when tank is very low? If it does I'd look hard at the filler.
We call ours "Ship Of Fools"
garypk is offline   Reply With Quote
Old 08-20-2015, 05:32 AM   #8
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
My 2004 Land Yacht did it on some pumps but not on others. It is fustrating when you have to hold the nozzle to fill the tank! I always thought it was a pump problem.
Airstream12557 is offline   Reply With Quote
Old 08-20-2015, 08:40 AM   #9
2000 31' Excella
Ontario , Canada
Thanks for the info.
Seems to occur at most stations. Some are worst than others. (Flying J) I can't remember when it didn't happen.
So does the 2005 have a vented tank???
Old 08-20-2015, 09:18 AM   #10
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Try setting the nozzle on its lowest setting. My Ranger often clicks off if the nozzle is at max flow.
Old 08-20-2015, 09:49 AM   #11
2000 31' Excella
Ontario , Canada
I would be happy if I could set it at the lowest setting. But it shuts off. I have to hold onto the flow control below the lowest setting.
I understand that air has to get out for the fuel to get in. So if no air vent then I would suspect the filler hose going into the tank has a kink or is too small. But workhorse wouldn't have let that happen????
So maybe a clogged vent???
Other than that, maybe what I have is what I was supposed to get???
Old 08-20-2015, 11:56 AM   #12
2000 31' Excella
Ontario , Canada
May have stumbled upon the solution.
Did a google search and found several RV forums with similar posts.
Problem may be with the vent tube. Apparently all/most chassis have one. comes out of the top of the tank runs along the filler tube to a "T" near the top of the filler tube. overfilling can cause gas to be in the vent tube that gets trapped in a type of "P" trap by a low spot in the vent hose. Gas cannot drain back into the tank and air cannot go up the vent so air goes back up the filler tube causing auto shutoff to click off.
Solution seems to be to realign the vent tube to ensure there are no low spots and drain away gas in vent tube. Several owners did this and the problem went away.
Seems reasonable to me in that I believe that the gas tank is right up between the main chassis rails and filler and vent line would have to be horizontal at some point to fit under the floor and get to the top of the gas tank.
I'll have a look and follow up on findings later.
Old 09-07-2015, 01:45 PM   #13
garypk's Avatar
1998 31' Land Yacht
I used to service pumps & Rav 4s are notorious spillers. Seems the tank is pretty flat w/ the filler.
Old 09-07-2015, 01:52 PM   #14
54 Flying Cloud
KrisE MN's Avatar
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids , Minnesota
play with angle if you don't have nozzle in far enough or angled too straight it can cause problems
KrisE MN is offline   Reply With Quote
New Noise and heater shutting down periodically movin-in Furnaces, Heaters, Fireplaces & Air Conditioning 9 01-13-2015 06:57 PM
Shutting down heater/furnace Ssmookler General Repair Forum 16 11-06-2014 07:19 AM
Arghh!! Generator shutting off 92landyacht Mechanics Corner - Engines, Transmission & More... 15 10-28-2014 08:17 AM
Door Not Shutting... doglickfarms Doors & Locks 1 04-25-2008 01:02 PM
Toilet Spray Nozzle Leak DaveJ Sinks, Showers & Toilets 1 10-12-2003 12:29 PM
