Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 08-05-2012, 03:57 PM   #1
two2go's Avatar
2002 36' Land Yacht XC Diesel 300 hp w/2slides
Galt , California
Gas Gage problem
We filled the tank on our 2002 land yacht yesterday for the last leg of our trip. We had about half a tank when we filled up. The gas gauge read empty after we filled up. Has this happened to anyone else? Does anyone know what the fix is?
Thanks in advance for your assistance!
two2go is offline   Reply With Quote
Old 08-05-2012, 05:39 PM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Most likely the sender in the tank is bad.
92landyacht is offline   Reply With Quote
Old 08-05-2012, 05:48 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Yep. Happened to me in my previous pickup truck. If you have an idea what kind of gas mileage you get, you can use the trip odometer to ensure you don't run out of fuel before you can get the sending unit replaced. Just remember to reset the trip odometer every time you fill up, and plan to fill up when you're about 100 miles shy of your minimum range, to allow a reserve just in case.
Old 08-05-2012, 06:20 PM   #4
1992 36' Land Yacht
Grayson , Georgia
Anything else giving you problems on the dash? If so it may be a fuse too.
Old 08-05-2012, 10:56 PM   #5
two2go's Avatar
Galt , California
At this point, nothing else on the dash is problematic.
any other ideas???
Old 08-05-2012, 10:59 PM   #6
two2go's Avatar
Galt , California
We do use the trip odometer and we will make sure to follow your suggestions until we figure out the problem and resolve it. Thanks.
