Old 05-27-2014, 06:29 PM   #1
1997 33' Land Yacht
Vanleer , Tennessee
Fuse Help
I blew the fuse that works the leveling jacks on my Land yacht trying to jump the breakers. Does anyone know where the fuse for the leveling jacks? The jacks were working fine and when i tried to raise them the other day nothing happened but a little clicking sound from the Breakers, any help there would also be greatly appreaceive.
Shorthaul is offline   Reply With Quote
Old 06-02-2014, 07:39 PM   #2
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
make sure the emergency brake is set,and the light is on on the dash
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 06-03-2014, 09:01 AM   #3
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
I believe the fuse is located on the computer control box under the dash. follow the leads from the keypad module to find the control box. Should be just to the right of the steering column. If that fuse isn't blown then the unit should derive power from the chassis fuse box on the left side of the foot well.
92landyacht is offline   Reply With Quote
Old 06-03-2014, 06:55 PM   #4
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Do you have the HWH leveling system?
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 06-04-2014, 06:16 PM   #5
1997 33' Land Yacht
Vanleer , Tennessee
No i think it is called the Big Foot Hydraulic levelers
Third wire on the fuse panel help flashbackk Batteries, Univolts, Converters & Inverters 9 05-01-2008 08:27 PM
Possible faulty fuse or short in lights? HELP!! chuman70 Electrical - Systems, Generators, Batteries & Solar 11 11-15-2007 05:05 PM
fuse help !!!! Shellie Electrical - Systems, Generators, Batteries & Solar 3 05-17-2006 06:24 PM
Help!!! Fuse or wiring problem? pamelake Electrical - Systems, Generators, Batteries & Solar 7 06-28-2005 08:35 PM
Fuse Block replacement - help Craig Electrical - Systems, Generators, Batteries & Solar 6 10-13-2004 03:01 PM
