Old 12-04-2012, 06:52 AM   #15
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Yep, sounds like a thermostat issue to me too. I just picked up a pair of cheap non-programmable digital thermostats from HD for $24 each. The system only uses two wires so installation is a no brainier. The thermostat even included wiring instructions for the two-wire setup. I like knowing exactly what temp it’s set to as opposed to the slide and guess analog units.
92landyacht is offline   Reply With Quote
Old 12-04-2012, 05:33 PM   #16
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Sounds like the same one I picked up.I'll let you know if it makes a difference.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 01-20-2016, 10:19 PM   #17
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
Had a somewhat similar problem with my 97 Land Yacht WB diesel. Furnace blower would cycle on as usual then you could hear the burner trying to light. After 5 automatic tries it stop till the main switch was reset off/on. The furnace would never stay fired up longer than 7-8 seconds.
RV mobile tech found the computer board, located outside, was defective. $125 later it was like new. In fact, tech said the furnace itself appeared to have never been in use. Considering the rig spent it's whole life in NC and FL, I suspect first owner only used the roof electric heat when necessary. That just was not enough heat for me in Montana
Mike1997 is offline   Reply With Quote
