Originally Posted by ppillard
Hello all,
My first post! I run a 1996 30' Land Yacht, and she has served me very well! I've done a bit of searching on this subject, but haven't found any good data on my problem:
How do I remove the front Television without destroying the mounting box it sits in? Figured I would ask you guys before I start doing some exploratory surgery.
Any help would be greatly appreciated!
Pillard
Mine is a 2000. If it is the same setup, pop the plastic caps off the screw washers, remove the four screws, and the frame comes off. The only thing holding the set in if I remember correctly, is a metal angle iron on the bottom. A slight lift and it goes over the block and slides out. The power cord plugs in under the panel below the passenger seat whuch is also held in by screws.
Frank
