Old 10-13-2007, 08:32 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Front Marker Lights 12 V Question
I have one marker light that does not work. I could not get power to the fixture so I pulled the connector out and found one wire was not crimped down enough to hold the wire in. I removed the wire from the connector and then put a volt meter to the black and white wires. I don't get a reading. My question is, are the two wires hot? or is one a negative and the other a positive. Most RV's just use one wire for hot and the ground is the RV. Appreciate any advice on 12 volt power to the fixture.
Steve
spat61 is offline   Reply With Quote
Old 10-14-2007, 01:00 PM   #2
geodrake's Avatar
1993 34' Legacy 34
olathe , Kansas
I assume you have a fiberglass shell motorhome. This being the case there is no chassi ground and the black wire is serving as the ground.
geodrake is offline   Reply With Quote
Old 10-19-2007, 11:11 AM   #3
spat61's Avatar
Marker Light
Geodrake,
Thanks for the reply. I was able to pull the light off and also pull the rubber boot out of the hole (Very difficult with a slanted windshield). Yes, it does have two wires. The holder portion that the bulb fits into is completely unuseable though. Do you know where I could buy new marker lights? I have a 2003 AS LY (Gas). Thank you.
Steve
Old 10-28-2007, 07:08 AM   #4
geodrake's Avatar
1993 34' Legacy 34
olathe , Kansas
Any auto parts store has a selection of marker lights. There, you should be able to find a close replacement.
Old 11-05-2007, 09:36 PM   #5
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Originally Posted by spat61
Geodrake,
Steve
I replaced one of the marker lights on my '94 LY - ordered them through an Airstream dealer - I think they were about $10 for the whole assembly.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Front Marker Lights spat61 Land Yacht/Legacy Motorhomes 3 10-06-2007 08:46 PM
Marker Lights 1953 Flying Lights - Interior & Exterior 3 01-24-2007 08:41 PM
Marker lights nyrabbit Our Community 6 06-20-2006 08:07 PM
Marker Lights ... sovereignrwe Lights - Interior & Exterior 3 08-08-2005 03:47 PM
marker lights bhsl8 Lights - Interior & Exterior 6 09-12-2002 06:01 AM
