Old 08-11-2015, 06:46 AM   #1
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
Front Jacks Stopped Working
Hi Folks,
Have a problem and looking for suggestions.
For some reason, the front hydraulic jacks on my '04 Land Yacht 30 stopped working; last used, without issue, about 3 weeks ago.
The rear jacks work properly and the front ones make a similar sound when the in-cab button is pressed, but no movement. Actually, the sound is a little different than I remember. The fluid level is at the top when the check bolt is removed, and I see no leakage under the coach.
As always, any and all help, thoughts or direction is greatly appreciated.
Regards and safe travel to all.
Randy
RAG is offline   Reply With Quote
Old 08-11-2015, 03:14 PM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Which jack system do you have?
92landyacht is offline   Reply With Quote
Old 08-11-2015, 03:41 PM   #3
RAG
RAG's Avatar
Thanks for the response......
It's the Power Gear product. This is what the touchpad panel looks like:
Old 08-11-2015, 04:24 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
If your hydraulic pump us working ( the noise you hear) then it's very probable that you have an issue with the electrical activation of the front extend solenoids.
Could be a wire connection issue or something more sinister....... like a problem in the control board.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 08-14-2015, 04:50 AM   #5
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
RAG, mine acted up one time. One set of jacks would work and the other would not. I activated the switch by the door to put the coach in "store" mode (disconnected the batteries). I left the switch off for a couple of minutes and then turned back on. The jack system then wortked OK. I likened it to rebooting a computer system. It worked for me.
Airstream12557 is offline   Reply With Quote
Front Jacks AWCHIEF General Repair Forum 4 03-05-2015 08:05 AM
'04 LY Leveling Jacks Stopped Working RAG Land Yacht/Legacy Motorhomes 10 03-29-2012 04:25 AM
Should we add front jacks ? lanceley 2002 - 2005 International 6 11-01-2009 02:31 PM
Scissor Jacks in Front? J Goertzen 2002 - 2005 International 1 07-02-2008 01:46 PM
need to replace both front stabilizer jacks charlie tuna Jacks, Stabilizers, Lifting and Leveling 12 08-23-2006 06:55 AM
