Old 08-05-2014, 11:29 PM   #1
1990 36' Land Yacht
Slidell , Louisiana
Front brakes
1990 Airstream Land Yacht
454 chevy engine
auto trans
Ive searched and searched but i cant find and front brakes parts or even any info on where i can get shoes....drums....master cylinder etc etc.
What type of gm frame are these built on?
Please help
ryjamsan is offline   Reply With Quote
Old 08-06-2014, 05:36 AM   #2
1997 31' Land Yacht
Mahone Bay , Nova Scotia
These are a P30 chassis. We take ours to our local truck garage, no problem getting parts. The VIN # will tell the garage all they need to know - chassis, parts, etc.
We had a whole brake job done, no problem.
On ours the auto park brake had been disconnected. Our garage adjusted the manual brake so that it will hold the coach.
wheelygoode is offline   Reply With Quote
Old 08-06-2014, 06:47 AM   #3
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
More specifically it's a Chevy P30 motorhome chassis. There are differences between the motorhome chassis and the others (commercial I-beam and forward control). As for brakes, you need to know if you have rear drums or discs. Don't assume drums as rear discs are pretty common. This is especially true in later years. More then likely you'll be looking for parts for a 1997 Chevrolet P30 on a motorhome chassis with dually rear wheels, disc brakes front and disc or drum back.
92landyacht is offline   Reply With Quote
Old 08-06-2014, 03:04 PM   #4
1990 36' Land Yacht
Slidell , Louisiana
Thanks. Thay imfo was enough to start looking up info and parts. Although i wont be sure which parts to replace until i pull it apart.
however i think my problem is with this auto brake crap design.
This is for a 1990 airstream land yacht 36 with a tag axle. Most posts and problem i read about are newer models so im not sure i even have the auto brake system because ive never seen a light on the dash.
Can anyone tell me why the tag and rear axle are 8 lug as well as the spare tire but the front is only five? If i had a flat on the front i would be screwed
Anyway thanks
Old 08-06-2014, 04:13 PM   #5
1992 36' Land Yacht
Grayson , Georgia
TAG and Rear axle are not 8 lugs but should be 10 lugs. The fronts are 5 bolt but any 10 bolt rim will bolt right up. The spare should be a universal 10 bolt pattern.
You don't have the auto park feture and be glad you don't.
Your 90 LY is pretty much the same as my 92. If you have any questions just ask.
Emergency flashers apply brakes and ID brakes detree Brakes & Brake Controllers 12 01-23-2010 09:16 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Replacing Front Hubs and upgrading Brakes on My 99 2500 Burb SaabLover Tow Vehicles 15 03-19-2008 05:09 PM
Brakes Or No Brakes 62safari Brakes & Brake Controllers 3 01-24-2006 09:18 AM
