Fresh water leak near outside shower access
My 2005 Land Yacht 30SO has a water leak when using the city water inlet. The drip is between the back of the rear tire and over the gray water holding tank on the drivers side. I have a feeling that the leak has to do with the outside shower/toilet flushout cabinet and plumbing. We get a wet carpet along the wall of the bedroom near the corner below the TV.
I have tried to remove the access door and aluminum box that the shower valve and flush inlet is housed in to see the plumbing. AS caulked the box in with so much caulking on all sides it doesn't want to pull out, even after removing as much caulk as possible with putty knives.
Anyone have any experience with getting access to the plumbing, inside or out?
Ken
