Old 06-03-2014, 01:03 PM   #1
JMSx2's Avatar
2005 30' Land Yacht Gas 30
Belgrade , Montana
File tank sensor
Anyone have an issue with the above and if so how did mechanic access the unit. I'm getting some erratic readings lately and talking to local shop to replace the unit starts with dropping the fuel tank but the rear jacks are in the way......
JMSx2 is offline   Reply With Quote
Old 03-15-2015, 09:02 PM   #2
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
fuel sensor
The sensor & pump are on what's referred to as a hanger unit & is inside the tank. Some will measure & cut an access thru the floor to get to it but it's meant to be serviced by dropping the tank. I just had the pleasure of doing this on my 98 30'. The jacks need to be removed to do this but they are easy- 3 bolts ea. I dropped the tank w/ 2 floor jacks, raised the MH some for more room, slid underneath pulled out the assy, pumped out the last 15 gals of fuel, cleaned out the tank, replaced pump & reassembled. Hope this helps you! Gary
garypk is offline   Reply With Quote
Kill File? guy99 Forum Admin, News and Member Account Info 14 04-11-2007 05:54 PM
How do I reduce the size of a picture file? DEO Forum Admin, News and Member Account Info 9 08-04-2005 12:41 PM
File Drawer RoadKingMoe 2001 Limited 0 04-24-2004 05:14 PM
To "file" or Not to" file" Raptorrider2001 Our Community 3 04-14-2003 08:20 PM
File too big eraffety Forum Admin, News and Member Account Info 3 02-18-2003 06:11 AM
