Old 02-13-2009, 02:40 PM   #1
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Exterior delamination repairs
Anyone had any experiance in the best place to take MH for exterior delam work? Most body shops I've talked to aren't all that interested. Also heard its hard to repair just certain areas,(repaires look as bad as bulge) and that the whole side should be replaced. Has anyone had this type of work done, and how did the job turn out?Previous owner was negligent in caulking around couple windows, and I would like to have work done if not crazy expensive.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 02-13-2009, 02:47 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Go to a boat repair shop or an aircraft composite shop, both should be able to help you, with the boat shop probably cheaper but a better job at the aircraft shop
Old 02-13-2009, 08:30 PM   #3
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Delamination repair
Gloran,
Here in Florida, some of the bigger RV dealers like Lazy Days have big
RV Body Shops and do that kind of repair. If you have anyone up in Michigan that does Corvette body work, that may be an alternative.
RV Body shops charge $85 and hour and a Corvette shop will be half
that. Ever consider a do it youself project? You can grind yur mistakes
off with fiberglass.
Paul
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 02-14-2009, 12:32 PM   #4
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I did contact one fiberglass repair shop, and it looked like he knew what he was doing. But his shop was to small to bring MH in side, I would like to have work done during winter months when I don't use coach as much.The storage garage I keep rig in is heated but I only have parking privilege, can't be tearing MoHo apart in it. Don't really have room at home even for a summer project. Has anyone ever seen a larger RV company like Lazy-Days work on a delam coach? I heard the AS factory in Ohio used to do repairs on their coaches, has anyone had body work done there?
Old 02-14-2009, 03:52 PM   #5
lynn's Avatar
The Airstream factory service center works on side wall delaminations.they do it from the inside.
lynn is offline   Reply With Quote
Old 02-15-2009, 01:27 AM   #6
2006 37' A-Series
Cypress , California
I had some body work done at the Airstream factory on the front end (all fiber glass). They did a very good job.
deanstock is offline   Reply With Quote
Old 02-15-2009, 05:51 AM   #7
Santart's Avatar
2000 31' Land Yacht
Kerrville , Texas
Go from the inside only!
I've been through this. Look at:
http://www.airforums.com/forums/f312...one-36557.html
and:
http://www.airforums.com/forums/f312...two-36870.html
AIR# 7463
Frank & Angela
2000 Land Yacht 30 MH
Texas Hill Country
Santart is offline   Reply With Quote
Flood repairs fridder13 Member Introductions 3 10-25-2011 07:52 AM
What Safety-critical repairs to leave to a pro? Airstream Dad General Repair Forum 0 09-28-2011 05:35 AM
A Must have manual for service and repairs John H. Classic Motorhomes 12 07-22-2011 05:44 AM
1999 3/4 Ton Suburban and Expensive Repairs tlavergne Tow Vehicles 29 01-31-2011 02:19 PM
Electrical Repairs Bettye Electrical - Systems, Generators, Batteries & Solar 3 01-29-2011 08:12 PM
