Old 02-21-2013, 06:57 PM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
exploring our new LY but some early quest.
have any of you any experience of why the high beams don't work? relay, fuse, switch, etc.?
does anyone know if the headlights are the standard rectangular sealed beam type? i want to replace the low beams with a HD conversion kit if anyone has any experience...
and this is dumb, how do i telescope out the steering wheel?
there appears to be a volume control and headphone jack over the bed, how does that suppose to work? can't get it to change the volume of the stereo.
anyone recommend a conversion package to add a dishwasher?
anyone recommend a conversion package for the stove that would include an oven? any cons to this?
thanks in advance!
JourneytoRet is offline   Reply With Quote
Old 02-22-2013, 06:36 AM   #2
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
I don't know about the headlights or steering wheel on your 2000, but maybe I can help on some of the other stuff.
The headphone jacks, speaker and volume control over the bed on our coach is for the TV.
We have never checked on a dishwasher, I wouldn't want to add the weight.
One of the first thing we did was replace the stove-top with a range with a full oven. You loose some storage drawers under the stove-top but you got to have an oven! We bought an Atwood http://www.atwoodmobile.com/images/A...esentation.pdf
Good luck, enjoy and keep us posted.
BarnacleBill is offline   Reply With Quote
Old 02-22-2013, 11:37 PM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
thanks in advance!
Not so dumb - when I had my LY, there was a knob on the steering column on the left below the multipurpose turn signal / high beam switch. As I recall, pushing down moved the wheel up and down and pulling it up set the tilt. A photo of what I had is here http://vsquare.com/blkmagikca/1107/m...images/020.JPG
BTW, mine was on a Spartan chassis.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 02-23-2013, 08:57 AM   #4
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
"anyone recommend a conversion package to add a dishwasher?"
Don't you have enough on your plate at the moment? Bringing in a new dishwasher usually results in some joy and a lot of grief.
The general result is the old dishwasher claims her seniority rights and asks for unreasonable compensation.
Dave
Old 02-23-2013, 10:30 AM   #5
i like the atwood conversion... might have to look into that...
Old 02-23-2013, 01:02 PM   #6
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
I wish mine came with an oven. May consider loosing some drawers to gain an oven as well.
92landyacht is offline   Reply With Quote
Old 02-23-2013, 04:42 PM   #7
it's a real bummer having to work 7 days a week when i want to come home and explore the ly in the daylight!
does anyone know of a convenient wire to tap into to provide switched 12VDC for the new radio i'm installing? ideally, it would switch off when i turn off the engine key or the generator.
Old 02-25-2013, 05:29 AM   #8
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
I feel your pain, I do have the weekends off.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 02-25-2013, 09:35 AM   #9
1992 36' Land Yacht
Grayson , Georgia
Personally I like having access to the radio when the ignition is off. That way I don't need to turn on the key to listen to the radio when parked. You may better find the answer to your question in the Flat Front/XL forum. That forum is more specific to the model you have.
