Old 04-28-2010, 10:46 AM   #1
1989 35' Land Yacht
Walnut Creek , California
Entry Door Lock Replacement
Hi,
Anyone know a source for a side entry door replacement lock.
I searched the forum but only came up with trailer locks.
I have a 1989 36' Land Yacht.
The lock handle is pulling away at the top inside the finger pull.
It is a flush mounted type with a vertical pull bar inside the flush mounted portion.
Any help much appreciated.
David
mortond is offline   Reply With Quote
Old 04-28-2010, 10:55 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
How about a picture?
There is a replacement kit that requires mounting an ugly plate on the outside of the trailer so lets look at repair first
2004 Excursion 4x4
Old 04-28-2010, 11:27 AM   #3
1989 35' Land Yacht
HI,
When it stops raining I'll go get some pics.
David
Old 04-28-2010, 11:49 AM   #4
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
David, if were talking trailers here, check out this thread for a replacement handle:
http://www.airforums.com/forums/f453...ing-41311.html
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 04-28-2010, 03:08 PM   #5
1989 35' Land Yacht
Hi,
Lock measures 5.25" high x 2.875" wide.
Looks to be made out of either pot metal or aluminum.
Tried editing pics to no avail. First & third pics. needs to be rotated clockwise. 5.25" vertical.
Could not see a name anywhere on the lock.
Same lock on drivers entry door except 5.25" is horizontal.
David
Old 04-29-2010, 08:43 AM   #6
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
We replaced a door latch on our rig that looks like yours. We had been looking for a replacement latch for a long time. We finally found one made by TRIMARK and ordered it from the RV Shop ( www.rvshop.com ). The guy there, Bob McFarland, is great to work with and can find just about anything.
Give him a shout and good luck.
BarnacleBill is offline   Reply With Quote
Old 04-29-2010, 10:31 AM   #7
1989 35' Land Yacht
Thanks Guys,
Looks like rvshop.com or John Burkey's SS version are what I am after.
Thanks for the quick responses.
David
Old 04-02-2014, 10:31 AM   #8
Full-timer
nickglase's Avatar
1988 34.5' Airstream 345
new york , New York
From what I can tell these two parts pictured above translate to TRIMARK part numbers:
TriMark series 030-0450 part number is: 11812-37
TriMark Door Handle And Lock Assembly 11298-35-RH Interior lock 11298 35 030-0425
These may no longer be in production but I found them via ebay. Will update this list after I do the install to see if there are any issues.
Nick
Urban camping in San Francisco, Ca
1988 Airstream 345 Motorhome
1964 Vespa GS
1982 VW Qauntum, turbo diesel
1979 Triumph Spitfire 1500
nickglase is offline   Reply With Quote
Old 05-05-2014, 08:53 AM   #9
Full-timer
nickglase's Avatar
new york , New York
By the way those, TriMark part numbers I posted earlier are exact matches to the OEM hardware.
1964 Vespa GS
Entry door bolt lock with an outside key willyd Doors & Locks 4 06-22-2008 01:07 PM
Entry door lock mandolindave Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 07-13-2007 12:32 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Numeric Entry Door Lock Combination/reprogram Tom & Janet Salhus General Motorhome Topics 6 06-09-2004 11:06 PM
