Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 04-11-2011, 05:49 PM   #1
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , New Mexico
Engine box Fasteners, Bolts, 1995 Cutter LE on Ford F53 Chassis
One of the threaded “nuts” that hold the engine box in place has striped out on our 1995 Cutter LE.
Here’s a couple of pictures:
Does anyone know where I can get a replacement?
BarnacleBill is offline   Reply With Quote
Old 04-11-2011, 06:21 PM   #2
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
If an auto supply place doesn't have it, you could try an aircraft supply place, just ask for an anchor nut in whatever size it is. Could also try someplace like Fastenall....Phil.
pgr32e is offline   Reply With Quote
Old 04-27-2011, 03:00 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Ace hardware might have, no matter what the price, it will be better than what it cost the PO at dealer to install new ones. I took the bolts into the shop and ground the bolts down to a point so that it is easier to find the hole and use fingers to tighten at least a couple of turns before using a wrench.
Old 04-27-2011, 03:35 PM   #4
1985 31' Excella
Fresno , Texas
Find someone that can install a rivnut. They work great I installed them in my truck bed to hold a hundred gallon fuel tank down. The kind I used had a gun similar to a rivet gun with the straight handles.Rivnut Fasteners & Bollhoff Installation Tools, Puller EZ & Custom Rivnuts - Blind Fasteners & Inserts - Bollhoff
Wsmith is offline   Reply With Quote
Old 04-27-2011, 03:41 PM   #5
1985 31' Excella
Fresno , Texas
Bill Didn't want to infer you couldn't install the rivnut I gave you the link too. I posted and then decided to find a link for you and didn't proof read my post. Sorry!! Last time I used one it was not this simple, It required a tool that was about $200. The video makes it look simple now. Good luck with your repair.
Wes
bolts, engine box
Ford F150 3.5L Eco Boost Streamer1492 Tow Vehicles 601 05-19-2014 08:05 PM
Fuel Filter (s) 1995 Cutter LE Ford F53 Chassis BarnacleBill Land Yacht/Legacy Motorhomes 2 04-12-2011 08:33 AM
Ford hitch 2.5" to 2" adapter hhendrix Hitches, Couplers & Balls 15 03-28-2011 08:32 PM
Shore power box and breakers? DanielB Electrical - Systems, Generators, Batteries & Solar 8 03-15-2011 06:33 AM
TV Questions - 1980 Ford F100 jmdotter Tow Vehicles 7 02-05-2011 01:48 PM
