Could be the flasher is out. They are not expensive. I would pull and replace.
MICHAEL
First check the wiring at the switch. Then check to see if somebody took the relay out of the fuse board. If you have a manual, check it to see the location in the fuse panel of the relay. Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
The OEM ones are in a small aluminum can and are the thermal type and can not handle the load when towing. Replaced with a 50A solid state from NAPA. A bit awkward to get at up behind steering web.
