Hi Paul,
Here's my experience with my '94 LY Diesel Pusher . .
First off, I had a problem with the air conditioner - it would sometimes work, and sometimes not. One of the mechanics at a Midas shop I did the network for went over the wiring under the hood on the road side - that's where you have most of your connections. He found that some of the crimped ends were loose. So he went over all of them - those that were loose, he refit the connections. He also showed me that there is a correct way to crimp. That corrected the problem with erratic airconditioning and heater/defroster.
Then, in October, I suddenly found that when I switched on the ignition, nothing happened. This occurred while I was camping and connected to 50-amp service. I found that when I pulled on the headlight switch, the ignition switched on.
There were several issues here, which I believe were linked. The first was that the main solenoid packed in. This solenoid is what provides the power to the switched buss from the always hot buss.
The other issue is one that resulted from improper modifications made at the time the unit was imported into Canada. Canada has a requirement for daytime running lights. When automotive equipment is imported, there is a requirement that the auto/truck/bus have daytime running lights installed immediately; once done and a Transport Canada sticker is affixed, then the GST tax is paid and the vehicle is now ready to be licensed. The garage which did this modification tried a real "Mickey Mouse" approach, and simply put a jumper between the headlights and the switched buss. Naturally, this was not documented, so the diesel shop spent many hours trying to diagnose the problem. The correct fix is to install a "daytime running lights module" which consists of a headlight relay that is activated by the ignition switch and derives its power from the always on buss, so that it does not overload the main solenoid.
The legal wrangling on this unsafe repair is soon to start, as the bill the diagnose this and repair it was mucho dinero.
One thing to note, Paul. There is a lot that vibration could do, so check that all your connections are snug, and that all wiring that had a crimped fitting is snug as well.
Howard
__________________ WBCCI #5957
VE3JDZ
1994 Land Yacht 34 diesel |
