Old 09-14-2018, 06:58 AM   #1
2004 26' Land Yacht Gas 26
Thibodaux , Louisiana
Driver Seat Will Not Turn 26LY
I have a 26LY and I have never been able to get the front seat to turn around. The latch under the seat releases but it will not turn. I can see grease where it spins. I also tried to loosen the nut in the bottom but it seems to be welded on. I was wondering if you have to have it in a certain position for it to turn. Also the seat back will not recline either but it is in position that I like so I never cared to fix it not sure if that has anything to do with it.
latenite23 is offline   Reply With Quote
Old 09-19-2018, 01:28 PM   #2
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
I have had this problem also and had to replace the cable mechanisms. The plastic tubing surrounding the cable wears out and the metal lever underneath the chair does not completely clear out of the way of the notch. Not certain where I got them. Just searched online and ordered them. They are relatively easy to replace. You should be able to manually move the spring loaded latch out of the way by using a screwdriver or pliers. Then you can rotate the chair. But as soon as you rotate the chair back to the forward position it will lock in place.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 09-20-2018, 07:22 AM   #3
My latch under the seat releases. The cable is broken but I can move it with my hand but the seat just will not turn.
Old 09-20-2018, 05:02 PM   #4
Hmmm, I see, not certain how to advise you. Would have to see it to help out. Can you send photos? I know it's a tight area to photograph, but if you could post a couple photos would be happy to try and help.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Condensation in engine compartment 26ly latenite23 Land Yacht/Legacy Motorhomes 1 12-03-2017 06:31 PM
Motorhome driver's seat - 1995 pol Land Yacht/Legacy Motorhomes 10 01-20-2016 10:07 PM
Driver seat does not pivot 180 dateem Land Yacht/Legacy Motorhomes 11 11-12-2014 02:32 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Power to Driver seat and side window humoso Land Yacht/Legacy Motorhomes 1 05-15-2005 07:20 AM
