Old 07-11-2012, 11:11 AM   #1
pol
1995 30' Limited
1995 31' Land Yacht LE
Seattle , Washington
drawer slides
Does anyone make replacement drawer hardware for a 1995 Land Yacht LE?
pol is offline   Reply With Quote
Old 07-11-2012, 02:03 PM   #2
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
You will need to look at what you have to identify the hardware. I just ordered drawer supports for my 99 Excella.
http://www.airforums.com/forums/f38/...are-24459.html
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 07-12-2012, 04:14 AM   #3
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
I took off the broken hardware and took it to the Big Box hardware stored to locate my needed hardware.
Sam
Airstream12557 is offline   Reply With Quote
Old 07-12-2012, 06:20 AM   #4
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
pol,
There are a number of high quality cabinetmakers and architectural woodworkers in the Seattle Area, all part of the Architectural Woodwork Institute Washington Chapter. Private Message me and I'll send you to a link on our website by which you can search.
These guys and gals have access to the widest range of specialty hardware from all over North America. I'll bet one of them would help you find what you need.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-12-2012, 09:55 AM   #5
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
We bought replacement drawer hardware for our 1995 Land Yacht LE at the local RV Store in Tarpon Springs last winter.
BarnacleBill is offline   Reply With Quote
Old 07-15-2012, 09:05 PM   #6
1991 36' Land Yacht
Catawba , Virginia
Most of the drawer hdwe can be found at about any hdwe store. If you have an 84 Lumber nearby they have people that handle commercial accounts and they can usually order anything you need an can also get you new drawers. Get your dimensions and you just R&R the drawer fronts.
Road Dawg 36 is offline   Reply With Quote
Old 09-29-2012, 07:34 PM   #7
1995 35' Land Yacht Diesel
Roswell , Georgia
Drawer hardware
Just went through the same search trying to find end brackets for the factory drawer slides. Slides and all hardware are readily available on Ebay. Just search HOUCK 051 and you will get the part that holds up the rear of the slide and you will also see quick links to all slides. 1995 LE Pusher has both 18" slides and 14" slides. Houck made all the locking drawer slides in the coach that year....at least on mine.
batwingz is offline   Reply With Quote
Old 10-01-2012, 11:30 PM   #8
1996 33' Land Yacht
RANCHO CORDOVA , California
I got sone for my 96 LY at the local Woodcraft store. They should have one in Seattle
zagos24 is offline   Reply With Quote
