Originally Posted by azflycaster
Cooling my fridge in my 75 is an overnight process.
Rich.
If the reefer is empty, it should get cold in a couple of hours.
Make sure the burner and orifice is very clean. That should be done every 3 to 4 years. The LPG pressure should be 12 inches.
Also, since you live in a place that has way too much heat, installing a cooling fan behind the reefer that blows cooler air up thru the coils, and out of the roof reefer vent cover, will definitely help.
You can get those cooling fans that operate on solar power, so you don't have a battery drain.
