Old 05-04-2014, 10:02 AM   #15
Johnsito's Avatar
1997 31' Land Yacht
I have a 1997 P30 chassis and it has auto park. What a nightmare if it goes out. I had the main component removed and repaired and it is running fine again. You need to be sure that when you put the RV in gear, you wait for the auto park light to turn off before moving the vehicle. You may also want to have a spare "green" switch handy. That is usually the fist piece that goes out and the easiest to replace.
Johnsito is offline   Reply With Quote
Old 07-12-2014, 01:37 PM   #16
1997 31' Land Yacht
Mahone Bay , Nova Scotia
Our '97 originally likely had the auto park, somewhere down the line a PO dismantled it. When it was in for brake work (rear calliper seized) when the mechanic fixed the brake then it wouldn't hold at all in park with parking brake on if there was the slightest incline. The mechanic then fixed the drum on the driveshaft so that it was tight enough to hold. Works perfectly. Stop, put in park, engage parking brake and we're not moving.
wheelygoode is offline   Reply With Quote
Old 08-06-2014, 03:12 PM   #17
1990 36' Land Yacht
Slidell , Louisiana
So i assume my 1990 land yacht 36 doesnt have auto brake. Makes me think my left front locking up as i come to a complete stop is more.likely a wheel cylinder sticking or a master clyinder sticking. Count to ten and it releases and you roll fine until you have to stop again
ryjamsan is offline   Reply With Quote
Old 08-07-2014, 04:09 AM   #18
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
My 92 has park in the trans and an emergency brake.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Top of Georgia Airstream Park Communications Forum Wanted Bohemian Other Clubs 58 12-27-2015 01:39 PM
Auto Park Pressure Switch Wiring Diagram Road Dawg 36 General Motorhome Topics 0 02-04-2012 01:24 PM
Ohio & Mississippi River Flooding Threaten Landmark Park overlander64 On The Road... 14 05-03-2011 09:59 AM
boondocking in Big Bend Park Texas greenisabel Boondocking 3 03-30-2011 06:54 AM
Workamping Opportunity At Penn Wood Airstream Park DEITZ645 Working on the Road 0 03-14-2011 11:58 AM
