Old 09-20-2016, 09:42 AM   #1
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Diesel pushers popping up
Always wanted a diesel pusher and suddenly two show up in my area. I know they're serious fixer uppers but still hard to find. What do you guys think:
http://atlanta.craigslist.org/nat/rvs/5753174855.html
http://atlanta.craigslist.org/atl/rvs/5769092258.html
92landyacht is offline   Reply With Quote
Old 09-20-2016, 10:27 AM   #2
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I don't have any particular knowledge about diesel pushers but in 30 years of collecting Porsches I have learned a couple of things about buying vehicles from owners who don't maintain them - the mess you see is only the tip of the iceberg and the purchase price is just the ante. Most expensive vehicles you can buy.
John
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 09-20-2016, 10:34 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
I remember when you looked at the odometer and the last digit did not line up that was an indicator that it had been set back.
2004 Excursion 4x4
Old 09-20-2016, 11:11 AM   #4
2007 25' Safari FB SE
Suburbia , Sunny So Cal
They both look like big projects. If you are up for that. Pick the one without any water leaks in the shell.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 09-20-2016, 12:43 PM   #5
1989 34.5' Airstream 345
Ebro , Fla Panhandle
John shares some good advice above.
I don't know much about the fiberglass era motorhomes other than use a moisture meter thru out the coach, ceiling, walls, and floor when you go to evaluate them.
Realy low buy in price is only the start, do your best to determine what the needs are.
Even tho it's in mid project, try to check out all appliances etc.
Could be a deal because of the circumstances. Or a money pit.
Good luck in your search.
I was caught up with the quest for a D P classic, then realized the costs involved in getting one and the higher cost of repairs etc. not that much difference in function to justify the additional cost for me.
Cheers Richard
tevake is offline   Reply With Quote
Old 09-20-2016, 01:43 PM   #6
1979 23' Safari
Wayland , New York
At least the second one has its dash and a drivers seat!
Old 09-20-2016, 02:09 PM   #7
The second one shows signs of multiple roof leaks, the one over the driver seems to have reached the wall.
We had a member post of similar damage on his coach. He ended up gutting it to the framing. Not clear if you are into going that deep.
How is the condition your current rig? I'd think you may be well situated to gage the condition of these type of rigs than those of us that are into the aluminum skinned types.
Cheers Richard
Old 09-20-2016, 03:52 PM   #8
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
For $8,500.00, does the shovel that's holding up the ceiling come included in the deal? If not, that's a deal breaker for me.
The first one for $4,000.00. I think the guy had a heart attack when he looked above his ceiling.
Again, thank God I have a Classic. Yes I had to replace my subfloor, but that's it.
Goodluck
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 09-21-2016, 11:27 AM   #9
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
If I owned it, that would be enough to give me a heart attack...
Old 09-21-2016, 02:39 PM   #10
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I suppose it depends on how badly you want one, and how much you're willing to spend. Personally, if I was going to put all the work into fixing up an Airstream motor home I'd want to do one of these: http://www.airstreamclassifieds.com/...-280-28-texas/
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 09-21-2016, 03:26 PM   #11
1973 31' Sovereign
Middletown , California
Of the two I'd go for the '94, the 93 looks like it has extensive water damage. If the '94 drives well I'd look it over really close for water damage but for the price you could do some fixen. Hope the MoHo isn't what caused the guys heart attack! Also as mentioned I'd rather have an aluminum MoHo, but you could always sell later if you want.
ijustlee is offline   Reply With Quote
Old 09-21-2016, 03:30 PM   #12
1994 35' Land Yacht Diesel
Denton , Texas
Agree with previous posts. Start with figuring out what doesn't work.
Generator several thousand potential
A/c units. $700 each to replace
Dash a/c $1-3,000. If it doesn't work you will run the genny for air. $30-50 per day of driving
Leaks - look for delamination on sides. 8500$ one definitely has leaks by the fan and shovel area. Figure removing the headliner, overhead cabinets, removing the Luan, replacing the foam, luan and headliners. Probably damage in the wall. Depending on how long it has leaked the steel frame members may need attention.
From the general view of it it doesn't show much pride of ownership which means you won't find a lot of the problems until you dig in. I would expect to spend $20k if you do most of the work yourself.
Recommendation is to wait for a well cared for one but if you go ahead I would look at the 4K one if it has minimal leak damage and major systems check out. My PO paid $15k and then another $10k and sold to me for $9k after a year.
dajen54 is offline   Reply With Quote
Old 09-21-2016, 05:23 PM   #13
Plover , Wisconsin
How about buying both of them and combining what is good in each?
Oxen is offline   Reply With Quote
Old 09-21-2016, 07:27 PM   #14
Paul Dobbin's Avatar
Franklin NC , North Carolina
This thread is getting depressing. We have a 94 Land Yacht DP that we've used and loved for 112,000 fun miles while keeping it inside when not traveling, We've had to make repairs but is that not what we should do. It'always ready to go on vacation. When I see these abused and abandoned Land Yachts, it makes me sick!
Sometimes we talk about selling it but these kind of threads tell us it's worth less than $16K, or thses junker prices and we say , #1 might as well keep it or #2 that's a lot of Hampton Inn rooms.
Decisions, decisions. What to do after two class A's and 27 years?
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Airstream Class A Diesel Pushers Available masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 207 03-22-2017 08:12 PM
Diesel pushers mtlagger Our Community 2 02-05-2016 09:03 PM
3 Diesel Pushers = 1 Airstream ShinyRoad Member Introductions 23 02-05-2016 08:54 PM
