Originally Posted by Paul Dobbin
No ours steers fine, just hard to make a U Turn when towing a trailer. Turnlng radius is pretty large, making wrong turns a real problem at times.
Paul
Have you looked at how the Miter Box is mounted? It is the gearbox that is coupled to the steering wheel shaft and then sends it towards the straight axle at less than a 90-degree angle.
The problem I see with it is about impossible to photograph and even when looking, it doesn't jump out and grab you unless you have somebody bumping the steering off one of the locks.
The mount-plate and miter box only deflects slightly, but, there should be zero movement of it.
I will try to video it and if your's is assembled the same, I suspect you'll want to have a look at it. It only is really noticeable in normal driving when a wheel drops off uneven pavement or catches a rumble strip.
It feels sorta like a tie rod end may be made of rubber, not so much worn out and clunky.
Mike1997, I don't see anything in my Spartan chassis manual that naming anything a "bell camber". In my years of less heavy steering and suspension work, I've never heard of such a part.
Is yours on a Spartan, EC2300 series I think is what mine is.
The Spartan has a straight axle and camber is a function of what I believe are unadjustable king pins and bushings, at least without bending the straight axle in a press, I think. I haven't dug in deep enough to see if any eccentrics are part of the design. If so, they would have to be just two position without affecting caster.
I'll have to look much closer at the manual and rig. I don't claim to have seen or know much of anything!
Perhaps a bushing was bell'd (worn) and they replaced a king pin and/or bushing?
