2003 39' Land Yacht XL 330 hp w/2slides
Cincinnati
Dash HVAC 2003 Land Yacht XL396
I cannot get the control that changes the direction of air on the dash HVAC system. For example:
Defrost, Lower/Vents, Vents only, ect. Fan speed operates, Temperature operates, on/off operartes. HELP!
The damper doors are most likely vacuum operated so check for small hoses under the dash and while the engine is running see if you have vacuum to the control.
If it is a diesel you will have a separate vacuum pump as a supply.
__________________ WBCCI 12156 AIR 3144 WACHUNG TAC NJ6 2004 Excursion 4x4 1991 34 ft. Excella +220,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
