Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 12-06-2014, 11:09 AM   #1
2003 39' Land Yacht XL 330 hp w/2slides
Cincinnati , Ohio
Dash HVAC 2003 Land Yacht XL396
I cannot get the control that changes the direction of air on the dash HVAC system. For example:
Defrost, Lower/Vents, Vents only, ect. Fan speed operates, Temperature operates, on/off operartes. HELP!
rrstory is offline   Reply With Quote
Old 12-06-2014, 12:57 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The damper doors are most likely vacuum operated so check for small hoses under the dash and while the engine is running see if you have vacuum to the control.
If it is a diesel you will have a separate vacuum pump as a supply.
2004 Excursion 4x4
Old 12-06-2014, 04:06 PM   #3
Cincinnati , Ohio
Dash HVAC
Thanks, It is a diesel. I'll take a look under the dash.
Ray #4983
Old 12-06-2014, 04:24 PM   #4
HowieE's Avatar
Images: 12
The vacuum pump will be in the engine area. It may be belt driven or a stand alone unit.
2004 Excursion 4x4
2006 Airstream Land Yacht XL396 eBay Watch Airstreams on eBay 0 02-08-2010 12:30 PM
2006 Airstream Land Yacht XL396 eBay Watch Airstreams on eBay 0 01-15-2010 10:50 AM
2006 Airstream Land Yacht XL396 eBay Watch Airstreams on eBay 0 12-07-2009 11:20 AM
2006 Airstream Land Yacht XL396 eBay Watch Airstreams on eBay 0 11-19-2009 08:09 PM
Airsteam Recalls 2000-2003 Land Yacht -- 08/07/2003 jpurdy Our Community 0 08-14-2003 07:19 PM
