Old 12-14-2011, 09:09 AM   #1
Santart's Avatar
2000 31' Land Yacht
Kerrville , Texas
Dash Air Conditioner Problems
A good time of year to be working on this since we are in Texas and it is too hot to mess with it in the summer. But in the summer for some time now, the A/C cools things down okay until awhile later when it sounds like one of the doors in the duct system closes and it seems hot outside air is mixing with the cool output and it no longer keeps us cool. Hence we do most of our summer driving with the generator running and the coach air to keep us cool. Anyone else have this problem? Any ideas of where to look for the control doors, relays, etc.? Are they accessible behind the dash? Or am I going to have to bite the bullet and take it to a A/C specialist?
AIR# 7463
Frank & Angela
2000 Land Yacht 30 MH
Texas Hill Country
Santart is offline   Reply With Quote
Old 12-14-2011, 10:13 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 58
Merry Xmas
1: Use the "search" option in the header above and your question may be addressed.
2: Go to the motorhome section and search. Many have detailed their problems and solutions there.
3: Always post pictures of the problem if you want a specific answer. There are many options on these units with different air/vacuum/cable controls.
Dave
Old 12-14-2011, 11:45 AM   #3
Santart's Avatar
2000 31' Land Yacht
Kerrville , Texas
Think I found the trouble. Removed the panel below the passenger side of the dash and found two vacuum control modules. When the A/C is in the normal position, the top one pulls in and air comes out. If I remove the vacuum tube and put it back on there is not enough oomph to reopen the door and help from a screwdriver allows it to work again. I will replace the module and see if it was the culprit. When it is in the MAX air position the module does not pull in at all.
AIR# 7463
Frank & Angela
Texas Hill Country
Old 06-15-2012, 07:30 PM   #4
kmamedia's Avatar
2002 26' Land Yacht 26
Seabrook , Texas
Yea I had that problem on my 2002 Landyacht, its the vacume hoses, mine deteriated after 3 years. I replaced them with rubber hoses, never had that problem again
kmamedia is offline   Reply With Quote
Old 09-05-2012, 02:54 AM   #5
1990 36' Land Yacht
Slidell , Louisiana
Hmmm mine will only blow thru the defrosters I w
Knew its a vacum problem ill check this weekend
ryjamsan is offline   Reply With Quote
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 06:40 AM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 10:35 AM
Land Yacht Dash Air DonaldW Land Yacht/Legacy Motorhomes 25 07-21-2011 08:48 PM
345 Dash Air 1987_345 Classic Motorhomes 1 07-18-2011 07:31 PM
need air conditioner ally 1965 - 1969 Overlander 2 07-02-2011 10:54 PM
