Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 10-19-2014, 11:24 PM   #21
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Bella, Dave, Thanks. My "hose" mostly a crescent, about half of it has just crumbled away.
A couple of weeks ago we took a long weekend, just about 100 miles to Calistoga at the north end of Napa Valley. It was about 95 degrees, and my a/c was blowing "cool" air. One of the longest 100 mile drives I have done, and only slightly better headed home. Now I will replace the hose and hope that is my only issue remaining.
I couldn't use the gen set/roof air: the gen set needs work, will only run for about 20 minutes. Maybe next week's project, just (finally) did a water dump and sanitize. The Napa Valley Fairground RV park had water that was not drinkable, but I had to put some in my tank and use the pump to work the sewer solution and spray out the black tank.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
TerraYacht is offline   Reply With Quote
Old 04-14-2015, 05:42 PM   #22
TerraYacht's Avatar
UPDATE: I replaced the white hose in the engine compartment first, hoping I did not have to fish the thick vacuum hose through the firewall, and just had a very pleasant trip to the NorCal Casini Ranch Rally.
Cliff & Andrea,
Dash Heat & Air Switch and Vacumn Lines spat61 Airstream Motorhome Forums 2 08-04-2018 12:52 PM
A/C switch for dash, run genset while driving? Bella123 Electrical - Systems, Generators, Batteries & Solar 4 09-17-2014 09:17 PM
Dash Ignition Switch crazeevw Classic Motorhomes 2 09-11-2011 08:54 PM
Dash Fan/Rear Monitor spat61 Mechanics Corner - Engines, Transmission & More... 1 09-30-2009 07:16 PM
Need help with "No Dash Fan" spat61 Land Yacht/Legacy Motorhomes 4 09-24-2009 04:05 PM
