Old 12-10-2012, 02:47 AM   #1
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
Darn I thought I fixed my leak
These leaks are hard to find. This one is over the passenger seat, I think it either coming from the antenna or the complicated area at the front end of my awning/trim piece over the window.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 12-10-2012, 04:06 AM   #2
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Bummer, double check the end cap where it ties into that area where your Eterabond ends also.
e
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 12-10-2012, 04:49 AM   #3
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
The area I circled is where it ends. I was trying to not see the tape from the ground. I am really hoping its the antenna.
Old 12-10-2012, 06:10 AM   #4
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Nope its not the antenna, gonna have to dig. What is the clear sealant Airstream uses over the 1 inch trim above the window?
Old 12-10-2012, 11:58 AM   #5
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
We had a leak, with the water ending up on the passenger seat. Turned out to be the top of the black windshield rubber (see red circle in photo) and easily fixed with clear aquarium sealer.
Good luck!
RAG is offline   Reply With Quote
Old 12-10-2012, 05:19 PM   #6
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
"easily fixed with clear aquarium sealer"
Good information. Mine began to leak after a winshield reolacement and was fixed by the glass installer. Now e all know the trade secret. Thanks
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 12-10-2012, 05:29 PM   #7
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I think this is where my leak is coming from
Name:	leak front.jpg
Old 12-10-2012, 05:52 PM   #8
RAG
RAG's Avatar
When I thought I knew where my leak was coming from, I covered the area with plastic & tape and then poured a few buckets of water over it to test the theory. A crude way for sure, but it worked and that's what counts.
Old 12-11-2012, 06:29 AM   #9
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Don't forget the marker lights at the front of the end cap as they're known to leak. The curved strip on the side of the end cap leaked on my 92 LY too.
92landyacht is offline   Reply With Quote
Old 12-11-2012, 08:14 AM   #10
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I think that curve strip above my side window is leaking I wonder what clear sealant I need for that ?
Old 12-11-2012, 09:08 AM   #11
2000 31' Land Yacht
Fort Erie , Ontario
My leak was at the endcap where the curved coverplate is.Put in an acrylic based based goop.
is.chowa is offline   Reply With Quote
Old 12-11-2012, 11:36 AM   #12
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I removed the 1" connecting strip,and cleaned off all the old caulking. Mine had a gap between the roof cap and the side panel so you can reseal that area quite well. At the same time I also left enough caulk that could squeeze out past the metal and wiped it clean leaving a fine bead of caulk next to the metal strip.
i did both sides the same way and haven't had a problem since. That metal strip comes off easily.I used Dicor white caulk, when you wipe it tight back to the metal I found the white looks fine. I don't know if it comes in clear.
Old 12-11-2012, 12:45 PM   #13
1992 36' Land Yacht
Grayson , Georgia
Yep, I'd remove the entire strip (you may need to use a spatula to remove it) and calk under it. I did the same but used 3/4" butyl tape under the strip and a gray acrylic calk along the edges. No leak for over a year.
I would never use silicone calk on the exterior surfaces. The silicone will separate over time and the leak will return. Silicone is much harder to remove cleanly in the future as well since it leave a residue that's tough to remove. Many conventional sealants will not adhere to silicone so future applications of non-silicone products may fail in a very short time.
Old 12-16-2012, 02:09 PM   #14
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
After more looking the place I thought was letting water in is lower than the water
Name:	leak pics 001.jpg
ID:	174742   Click image for larger version
Name:	leak pics 002.jpg
Name:	leak pics 003.jpg
