Old 02-28-2013, 01:11 PM   #29
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
I found a brush (not stiff wire) on a drill helps a bunch getting the old off.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 02-28-2013, 02:08 PM   #30
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Originally Posted by masseyfarm View Post
If you have a crack in the corner of a skylight, or leak anywhere else on that roof, the water may travel down the roof to sidewall joint and drip out at the front or rear cap. Sure is an annoying task looking for leaks that may not show up for hours after a rainfall.
Dave
and you can only fix them 1 at a time.
Old 03-09-2013, 06:18 PM   #31
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I wonder why this dude leaked? Every screw was rusted away except two
And after replacement of both fan/vents.
ID:	180599   Click image for larger version
Old 03-13-2013, 03:42 PM   #32
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
all I can say so far is,"No news is good news"
Old 03-13-2013, 05:43 PM   #33
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
But has it rained???
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 03-14-2013, 05:24 AM   #34
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Yes it has, and a pretty good one too.
Old 03-17-2013, 04:30 PM   #35
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Well we have had lots of rain and snow and I can say I appear to be leak free. I just want to say these leaks can venture anywhere, I had leaks in one place inside to come from at a place far away from the roof leak point. All I can say, look everywhere.
Old 03-17-2013, 05:25 PM   #36
eljay's Avatar
1968 24' Tradewind
Whooohooo! I'm waiting for the weather to cooperate so I can start sealing the seams and vents. (Not necessarily in that order) Identification of the potentials is the first step. Accumulating the necessary materials was the second. Waiting for warmer temps is the third...
Eljay
Old 03-17-2013, 05:34 PM   #37
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
go for the vents and skylites first
Old 03-25-2013, 05:56 PM   #38
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
THEY'RE BACK!!! at both rear corner cabinettes.I am very disappointed in Eturnabond .
Old 03-25-2013, 06:06 PM   #39
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
If the Eternabond has failed,(lifted) it is readily noticeable with a quick inspection. Just remove the failed area and clean again before patching. Installation of Eternabond is only as good as the cleaning job before installation. I check mine regularly for any sign of a bubble under the tape.
If the tape looks good, then your leak is somewhere else. Sewer vent, etc.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 03-26-2013, 06:46 AM   #40
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
I agree with Dave. I wouldn't blame the Eternabond tape. Many, including myself, have had great success with it. If there is ANY silicone residue or other containment between the Eternabond tape and the surface it will not adhere. In my case I found that the PO had used silicone in spotty areas around vents and skylights. Each time I had an adherence issue it was always related to this. Cleaning with acetone just seems to spread the silicone around. It takes a good cleaning with TSP to get the residue off. If the tape is sticking then the seal is good. Water can not penetrate a good Eternabond seal.
Try to locate the source of the leak by using a hose and directing water at areas on a dry day. Soak an area and let it sit for a few hours before you check for leaks in another area. Check all areas that you've used the Eternabond tape and look for lifted areas. If you don't find any, then start to suspect areas that you didn't use the tape on, like AC openings.
92landyacht is offline   Reply With Quote
Old 03-26-2013, 12:49 PM   #41
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
All the seams including at the back all looked good before applying Eturnabond. I applied Diecore around the base of those and don't think water is getting in. Maybe the box mounted to the roof which is in the center and I wouldn't think water would go there. This leak has been around a long time, the tops of the cabinets are rotted away.
Any thoughts?
By the way this is an older pic before replacing the skylite and 2 vents
Old 03-26-2013, 08:19 PM   #42
1992 36' Land Yacht
Grayson , Georgia
I'd be suspicious of the AC and any of the rail mounts.
