Old 03-08-2013, 09:06 AM   #169
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Just curious as to why you decided to add the 1/4" plywood underlayment? Is the current sub floor not compatible with the new floor squares? Seems that, properly cleaned and/or painted, the original sub floor (assuming in good shape) should accept the carpet squares by it self. I would think that it would add weight with little benefit for carpet.
I'm thinking of adding some underlayment to mine but I'll be putting down a floating floor instead. I have a few sheets of 1/8" luan plywood that's left over from the wall rebuilds.
92landyacht is offline   Reply With Quote
Old 03-08-2013, 11:01 AM   #170
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Carpeting doesn't seem to be the product of choice by most members lately, because of cleaning, oders, and wear. But there are the benefits of a warmer surface, ease of installation, cost, and quieting of road noise when traveling. When I replaced mine I wanted it to look original so I stayed with the carpeting, and have been very happy with it. Looks like your wife made a nice choice.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 03-08-2013, 11:51 AM   #171
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
I agree with the benefits and curses of carpeting, but I will take carpet over tile any day for the sitting and bedroom areas. Carpet does require a bit more care, but is easy to replace when the time comes to update.
Keep the pictures coming on the installation of the squares.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 03-08-2013, 11:58 AM   #172
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
I have been thinking of a more solid surface than carpet as said before for ease of cleaning. Some fellas I work around made the comment to use vinyl strips. I thought I might go that route. I am enjoying your progress reports too.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 03-08-2013, 01:13 PM   #173
"Alumi-holic"
cesalie2's Avatar
1982 31' Airstream 310
Memphis , Tennessee
There are several areas of the subfloor that are not level...appears to be where two sheets butt up together...
Between the dining table and the kitchen counter:
Between the twin beds:
And under the dining table...
Unlike traditional carpet, carpet squares do not use an underlayment of thick carpet padding. Each square contains the carpet, pad and backing. In order to minimize the "bumps" where the sheets join, My buddy recommended that I install 1/4 inch plywood across these areas with construction adhesive and screws to secure.
cesalie2 is offline   Reply With Quote
Old 03-08-2013, 01:28 PM   #174
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
when I installed Linoliam and my Airstream trailer Andy told me to put the edges along the edges of the plywood so that the trailer could expand and contract with heat. I kinda thought that made sense I don't know if it applies to a motorhome or not. just food for thought
Old 03-08-2013, 01:29 PM   #175
"Alumi-holic"
cesalie2's Avatar
Memphis , Tennessee
One distinct advantage of carpet squares is the ease of cleaning, removal for liquid spills (as many as 5 grandchildren at a time), and most important...DW can change the color, style, texture whenever she desires...
"A happy wife makes for a happy life"
Here are several alternates she is considering for the future:
If you consider she can buy and have shipped to us for $200-$250 (for 18 square yards and ease of installation ( just use old squares as a template), it becomes a palatable option...
Old 03-08-2013, 03:30 PM   #176
1992 36' Land Yacht
Grayson , Georgia
Personally, I would simply sand the sub floor joint edges to a matching height instead of adding another 1/4" layer to the entire surface. The additional plywood would add weight that could be used for other purposes. The gaps in the sub floor seem to me to be expansion joints that are intentional. Would not effect standard carpet or a floating floor, but may interfere with a stick down application type of flooring. By screwing and gluing over the joints you may be defeating the purpose of the joints and cause stress elsewhere. Just something to think about.
Old 03-09-2013, 05:36 AM   #177
"Alumi-holic"
cesalie2's Avatar
Memphis , Tennessee
92landyacht,
You raise a good point, will have to mull it over.
Old 03-09-2013, 05:43 AM   #178
"Alumi-holic"
cesalie2's Avatar
Memphis , Tennessee
Layed out a couple of carpet squares to get a preview:
DW and her friends call it the "Fun Look"
Old 03-09-2013, 05:54 AM   #179
"Alumi-holic"
cesalie2's Avatar
Memphis , Tennessee
My best friend is having a birthday celebration weekend (his 70th).
What better way to celebrate than a Crawfish Boil!
Old 03-09-2013, 08:53 AM   #180
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I agree with the sanding down of the uneven surfaces. Then you could skim it in with a floor leveling patch. OSB subflooring can be quite rough, when I replaced the oak flooring in my galley, removing existing oak damaged the OSB badly. The floor leveling patch worked great. In your situationwith the carpet squares, you might want to consider sealing or painting complete subfloor before inslalling carpet, if you decide not to use a 1/4" sub floor. I wouldn't worry about filling in joints cracks with patch material as an expansion problem,its too small of area. But OSB is highly susceptible to swelling when exposed to moisture.Thats the reason for the sealing of it under the carpet.But the sanding and leveling way might be easier and cheaper than the plywood.
Old 03-09-2013, 02:34 PM   #181
"Alumi-holic"
cesalie2's Avatar
Memphis , Tennessee
Thank you, 92landyacht, Gloran and others for your suggestions!
Sanded edges of the chipboard and used Durhams Rock Hard Water Putty as a floor patch:
Dining Area:
Between Dining Table and Kitchen Counter:
Bedroom:
Will let the patch dry overnight (left a small heater on low in the coach) and sand in the morning.
Plan to seal the floor with Kilz in the morning, hopefully start laying the carpet squares after lunch.
Old 03-09-2013, 03:34 PM   #182
1992 36' Land Yacht
Grayson , Georgia
Sounds like a good plan. Tomorrow I'll be doing a similar job, but I'll be doing a click-lock laminate floor so floor prep will be a little differant. I'm also pretty sure that I'll have some water damaged areas under the rug to repair since I had water intrusion from roof leaks when I purchased the MH. I'll keep you all posted.
