Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 07-13-2008, 09:24 PM   #1
cutbrain
Profile:  summit , New Jersey
cutter 1997 ford 460
I bought a 97 and en-route to shipping the vehicle it lost power. The fuel pump was found to be defective and was replaced. The front air did not work and the compressor was replaced. The generator did not work and a line was changed and it was said to work. Now when I take it for hilly ride it loses power after a while. The driver who took it 600 miles said it was fine except the last few miles when it acted up, he stopped the engine for 10 minutes and it was fine. I have found that stopping it for 10 minutes does the trick. But why is this happening? Did something happen after 600 miles after getting fixed. Also I get no air out of the front air conditioner and the generator will start for a second and then stop.
On another issue the holding tanks claim to be full when they are completely drained. I suspect that the tanks were not taken care of and have a less than pleasant sediment caked on. I really likethis vehicle but want everything to work well before thinking of a long trip.
thanks
jc
cutbrain is offline   Reply With Quote
Old 07-14-2008, 12:09 AM   #2
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Holding tank sensors are notorious for not working properly. The tanks are probably fine.
There are several possibilities for the loss of power. I would start at the fuel filter. If you still have a problem, take a look at the in-tank fuel filter at the fuel pick-up tube. That filter is shaped like a sock, and as it gets dirty it can collapse and shut off the fuel.
Good luck,
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 07-14-2008, 07:24 PM   #3
cutbrain
thanks the only thing that worries my about the fuel filter is that it seems to happen after running for a few hours in demanding conditions. Also, why does stopping for 10 minutes remedy the problem after awhile. I agree I should start there though.
thanks again
jc
Old 07-14-2008, 07:29 PM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
all over , Fulltiming
Images: 58
thanks again
jc
It could be the trash that is cloggin the sock falls away and settles to the bottom of the tank again.
It could also be vapor lock. The Ford 7.5 tends to run a bit hotter in motor home conditions than the GM 7.4.
Change is inevitable, except from a vending machine
AIR#2611
Old 07-19-2008, 11:19 AM   #5
cutbrain
is there a manual with images that would show me how to check the fuel filters? also is there a general manual for this chassis? How do I get one?
Anyone familiar with a Ford 460? QuietWater Mechanics Corner - Engines, Transmission & More... 13 08-21-2008 03:14 PM
Ford 460 Air Intake noiva Mechanics Corner - Engines, Transmission & More... 5 04-15-2006 07:19 PM
1992 B Van Ford/460 bobby_409 Sprinter and B-van Forum 7 01-27-2006 06:10 PM
Ford F-250..460 ci George Jr. Tow Vehicles 5 07-18-2004 07:54 AM
1997 A/S Cutter 35 (DP) dleslie125 Airstream Motorhome Forums 1 03-30-2003 11:53 AM
