Old 04-20-2010, 12:34 PM   #1
1995 35' Land Yacht Diesel
Downers Gorve , Illinois
Cummins B5.9L 230 HP Turbo Diesel w/Allison MD-3060 6-speed transmission
Hi I recently purchase a 1995 35í land yacht wide body pusher. I am missing some type of overflow plug on the housing between the Cummins Diesel engine and the Allison transmission. I believe it is the torque converter cover.
Itís a large treaded bolt whole right on the bottom of this housing less than 1". Does anyone know what this is, my oil levels are all good (trans and Diesel) thatís why I think itís an overflow of some type.
Thank you.
1995LY is offline   Reply With Quote
Old 04-20-2010, 06:05 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Jim,
I could easily be wrong, no experience with your combination. But the Cummins 5.9L used in Dodge applications has 2 holes in the engine to transmission adaptor housing below the turbo one is used for access to the torque convertor bolts and the other allows you to insert a BARRING tool into the housing that allows the engine to be turned over using the tool for valve adjustments and timing work and any other reason to slowly rotate the engine for service.
ENGINE OFF! Look into the hole and see if you feel the flexplate and try to rotate the engine by hand and see if a bolt appears. If you feel the ring gear, then I'd bet it's the BARRING tool hole.
No guarntees.
GCinSC2 is offline   Reply With Quote
Old 04-20-2010, 07:34 PM   #3
Photo Attached
Thanks GC, i took another look and it appears to be part of the Cummins Diesel housing - because of the color (paint). I still believe it's the shroud over the Torque converter. I also attached a photo which may help.
Old 04-21-2010, 05:43 AM   #4
GCinSC2's Avatar
5.9L Barring Tool Hole
I'm sorry, I do not know what your plug hole is for. The pic will definetly help someone identify it.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
Old 05-10-2010, 10:06 AM   #5
Follow up
3/4" black pipe plug fit perfect.
Old 10-19-2010, 11:25 AM   #6
1994 35' Legacy Diesel
Rayne , Louisiana
Images: 8
mine looks the same no plug, did you put pipe plug
YACHTSTER is offline   Reply With Quote
Old 10-19-2010, 04:24 PM   #7
1994 36' Classic 36 Diesel
Molino , Florida
On my 95 classic It is were I see the rear engine seal leak not bad yet. 1qt every 5000
mi IKE
uism is offline   Reply With Quote
Old 10-19-2010, 04:58 PM   #8
2005 28' Safari
Mono City , California
Most all mid-range and heavy-duty diesel engines have the same type of hole in the flywheel housing. The hole is never plugged, it can be used on many engines to bar over the engine by using a screw driver through the hole by prying on the flywheel ring gear teeth. As mentioned before it can be used to tell when your rear crankshaft seal is leaking and the transmission input seal also.
Tom
TBSarfari28 is offline   Reply With Quote
« Air filter | Top | photo »
ford v10 and allison 5 speed auto wmarsha Tow Vehicles 0 08-21-2009 12:47 PM
Allison Transmission Problem Aggiehusky14 Land Yacht/Legacy Motorhomes 11 05-12-2009 12:04 PM
GMC Allison Transmission Overheat 2dabeach Tow Vehicles 7 07-20-2007 07:15 PM
Where is the Speed Sensor? (Allison Tranny Error) Griffin Mechanics Corner - Engines, Transmission & More... 4 12-16-2003 04:57 PM
Allison Transmission ??? thenewkid64 Mechanics Corner - Engines, Transmission & More... 8 12-01-2003 01:52 PM
