Old 08-14-2019, 07:01 PM   #1
Pottsville , Pennsylvania
Cruise Control
I have a 2004 26ft Land Yacht motor home. The last time I used it, the cruise control didn't work. It did work the previous time. Is there a fuse somewhere that gives it power, or were does it get power from. Your help is greatly appreciated. Thanks Rusty
Rusty4cyl is offline   Reply With Quote
Old 08-14-2019, 08:45 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome aboard...👍
Ck the brake actuator switch...if it's bad the the cruise thinks your braking and won't engage.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 08-14-2019, 09:06 PM   #3
ITSNO60's Avatar
Tucson , AZ
Also check the brake light lamps, burned filaments can cause CC to become inoperative on some vehicles. LED lamps can also cause CC issues on some older vehicles.
Brian
ITSNO60 is offline   Reply With Quote
Old 08-15-2019, 07:10 PM   #4
Yes I applied brake pedal and all brake light's lit and released brake pedal and all light went out Thanks
Cruise or not cruise? badkat On The Road... 39 07-23-2016 06:37 AM
Cruise Control Chaplain Kent Mechanics Corner - Engines, Transmission & More... 4 10-14-2004 07:56 PM
1984 motorhome cruise control cooperhawk Airstream Motorhome Forums 2 12-25-2003 08:12 AM
No cruise control on '92 30' fangthorpe Mechanics Corner - Engines, Transmission & More... 3 05-09-2003 09:46 PM
Cruise Control Servo Diaphram zamboni Airstream Motorhome Forums 5 06-26-2002 09:14 PM
