10-30-2012, 12:36 PM
Ready to go campin?
1992 33' Land Yacht
Evans
, West Virginia
Clearance lights
Where do you get them for my 92 motorhome
92 Landyacht 33, 454 tag axle
10-30-2012, 01:53 PM
2018 25' International
Van Wert
, Ohio
Call Chris Burch, Service Advisor @ 937-596-6111 X7413....He might have them or point you in the right direction
10-30-2012, 05:31 PM
1994 35' Land Yacht Diesel
Franklin NC
, North Carolina
Clearance lights
I bought some at the local truck stop. Then I discovered that the whole fixture didn't need to be replaced, just the mounting screws, the gasket and the light sockets. I pirated the new ones for parts and rebuilt the originals.
Paul
"The Roadhouse" our Land Yachts name
10-30-2012, 05:34 PM
Ready to go campin?
1992 33' Land Yacht
Evans
, West Virginia
Mine have broken lenses . I wonder if the ones NAPA sells are the same
10-30-2012, 05:42 PM
2020 30' Classic
Commerce
I got mine Lowes.
10-31-2012, 08:01 AM
Streamin'
1995 30' Cutter Bus LE
Madison
, New Mexico
Check PPL
10-31-2012, 11:35 AM
Ready to go campin?
1992 33' Land Yacht
Evans
, West Virginia
I think its napa part# lit 1571D
11-01-2012, 12:37 PM
Ready to go campin?
1992 33' Land Yacht
Evans
, West Virginia
Nope, the napa light does not use the same lens.
11-01-2012, 01:21 PM
Registered User
1996 32' Cutter Bus
Petaluma
Check out the Truck-Lite catalog online.
They'll probably have it. Then when you find the part #, Google it to find a distributor or order it on Amazon.
http://www.truck-lite.com/
Good luck!
11-01-2012, 01:33 PM
Ready to go campin?
1992 33' Land Yacht
Evans
, West Virginia
Good luck!
Those are the same as the NAPA 1571 and 1571A even the part number is the same. I was really hoping to just replace the lenses.
11-01-2012, 02:05 PM
Ready to go campin?
1992 33' Land Yacht
Evans
, West Virginia
Originally Posted by masseyfarm
That looks like it, but I was hoping to get replacement lenses for now, till I get all my leaks found. and this is what the napa 1571d looks like and $4.29 each
11-01-2012, 03:39 PM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
I doubt you will find replacement lens for these old bulb style. The lamps are cheap to buy. But why spend money on obsolete stuff if you are going to upgrade anyway.
Buy a couple LED lamps or more and use the extra lens to repair your old lamps if needed.
NOTE: The lens from the LED lamps are not quite the same color as the old lens and should not be used on the old lamps and vise versa.
The problem with the old lamps, you have already experienced with the leaking.
The water runs down the back of the lamp and follows the wire inside. These old style lamps were made to be mounted vertically only, and the drain must be below the bulb housing. If the bulb housing gets any moisture around it, it will only drain inside to your insulation, long before it has rotted the bulb socket.
The LED are sealed and eliminate the leak problem.
Dave
[QUOTE;1223060]That looks like it, but I was hoping to get replacement lenses for now, till I get all my leaks found. and this is what the napa 1571d looks like and $4.29 each[/QUOTE]
11-01-2012, 03:46 PM
Ready to go campin?
1992 33' Land Yacht
Evans
, West Virginia
I will upgrade to LED when I have all the bugs ironed out on this beast. I just got off the phone from Airstream and they gave me a part number for the red lenses 510984-010 I have to call a dealer to purchase them. I hope they don't cost a fortune.
11-01-2012, 03:52 PM
Tub City
, British Columbia
The dealer will charge you the price of the new lamp, and just ship you the lens for about the same price you paid for the motorhome.
Dave
11-01-2012, 05:00 PM
Ready to go campin?
1992 33' Land Yacht
Evans
, West Virginia
Lol!
11-03-2012, 05:35 AM
Ready to go campin?
1992 33' Land Yacht
Evans
, West Virginia
The lens is $3.95 from Parkveiw RV
11-03-2012, 10:33 AM
Tub City
, British Columbia
If you are intent on staying with the old inefficient, leak style lamps, you should probably just buy a replacement for the extra $.34 /unit as you will need it sooner than later.
"That looks like it, but I was hoping to get replacement lenses for now, till I get all my leaks found. and this is what the napa 1571d looks like and $4.29 each "
Dave
11-04-2012, 09:08 AM
Streamin'
Madison
, New Mexico
Here's something to check out, I re-bedded our marker lights and they stooped leaking. If you re-bed yours check and see if they are on the right way up. There is a drain hole in the housing so condensation under the lens can drain out. I found about half of our lights with that hole facing up instead of down!
11-04-2012, 05:32 PM
1987 32' Excella
Nepean
, Ontario
The original clearance lights did not always have a good seal against water inclusion. As well, you could never know what the PO did. After constant fussing with clearance lights where the bulbs lost contact, and water managed to seep in around the the so-called gasket, I bought all new clearance lights from Dan (LED4RV.COM) - now they all matched, and led lights don't have the same issues regarding the contacts to the bulbs corroding.
After I sold the LY and bought a trailer, I did the same thing - all incandescent lighting, inside & out were replaced with LED's.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
